» Members: 10,447
» Latest member: bhushan1301
» Forum threads: 4,326
» Forum posts: 21,312
There are currently 390 online users.
» 0 Member(s) | 368 Guest(s)
Amazonbot, Applebot, AwarioBot, Baidu, Bytespider, Crawl, Google, PetalBot, Yandex, bot
kc868-a6 analog input
Yesterday, 09:56 AM
F24 ESPHome yaml for home...
Forum: F24
Yesterday, 07:25 AM
Forum: F24
Yesterday, 05:35 AM
Forum: F24
Yesterday, 05:33 AM
[Arduino source code for ...
Forum: KC868-A2
Yesterday, 05:31 AM
KC868-A4 – Relay 1 clicks...
11-03-2026, 11:58 PM
11-03-2026, 07:34 PM
» Replies: 24
11-03-2026, 03:04 AM
11-03-2026, 01:34 AM
11-03-2026, 12:15 AM
  Technical details about remote sold by Kincony !
Posted by: vincen - 12-15-2023, 12:07 PM - Forum: Suggestions and feedback on KinCony's products - Replies (3)
Hi
Kincony sells this product on aliexpress (radio remote) https://www.aliexpress.com/item/10050024...3e5fCX8MU8 but unhappy it's not indicated which battery to use with it !
It's some CR something but unable to find out which model !
Kincony support on Aliexpress is just dumb (sorry to say but it's reality, it's only able to tell you to contact them by whatsapp or link you to their youtube channel, or sending so bad quality pictures of products that you can do nothing with it Sad
Do someone has the info ? or someone from Kincony can answer please ?
Vincèn
  ESP32 chipset not working for rf module and led strip light from esphome
Posted by: homeassistant144 - 12-15-2023, 11:02 AM - Forum: KC868-Server Raspberry Pi4 local server - Replies (6)
RF module and led strip light gpios dont seem to be able to work together in this kc868 board. I tried for both seperately within esphome, once only using the RF and the next time only using the led code. No issues were seen until I tried to use them together. when i flash the esp32 with the code containing parts for both of these, flash shows to be successful but it doesn't come online in esphome. this is my yaml code i have been using in esphome.
.txt   yaml code esphome.txt (Size: 3.3 KB / Downloads: 622)
  KCS Firmware multiple DS18B20 on the same GPIO
Posted by: tamibandy - 12-15-2023, 10:49 AM - Forum: "KCS" v2 firmware system - Replies (3)
Is there implemented to can read multiple DS18B20 temperature sensors on the same GPIO?
If not, it is possible to implement some management for it by sensor's uniq id?
Another question, is the KCS firmware open source?
  Connecting analogue sensors
Posted by: fundisimu - 12-15-2023, 08:32 AM - Forum: KC868-A16 - Replies (11)
I am new to your board(kcs868-a16). need help testing the onboard LED indicators to see if they are working ok. Installed firmware and need to test if the outputs are ok. secondly need help connecting 0-5 v PH sensor. Do they already have input elctronics already inside or need external circuit for 0-5v signal.
  door sensor convert to RS485 in ESPHome using KinCony HAv2 module
Posted by: admin - 12-15-2023, 12:37 AM - Forum: Getting Started with ESPHome and Home Assistant - No Replies
  E16T work with multi HAv2 config by ESPHome in home assistant
Posted by: admin - 12-14-2023, 11:58 PM - Forum: KC868-HA /HA v2 - No Replies
.txt   E16T_esphome_HAv2.txt (Size: 7.47 KB / Downloads: 741)
  KCS http post ifttt/set
Posted by: stanchiam - 12-14-2023, 06:06 AM - Forum: "KCS" v2 firmware system - Replies (3)
I want to trigger the IFTTT using http post, example http://192.168.1.123/ifttt/set with payload {"cmd":"run","ids":[2]}
But was returned with {"code":-1,"status":"auth failed"}
How to post to trigger the  IFTTT?
Also, can I trigger the digital input using http? PDF only how to use set_output but not input
Thank you.
  Blind remote doesn't work with "KCS" v2.2.2 firmware
Posted by: ayeosq - 12-13-2023, 04:48 AM - Forum: KC868-AG / AG Pro / AG8 / Z1 - Replies (11)
Device: K868-AG PRO loaded with 2.2.2 as it, no added component
Blind remote model: AC123-02D
Tried RF learning via the KCS firmware 2.2.2, wasn't successful.
Aircon remote: Mitsubishi Aircon Remote
Tried to IR learn as well, it was successful but unable to transmit.
Any recommendation?
  KCS firmware missing input options, only have reverse option
Posted by: stanchiam - 12-13-2023, 02:27 AM - Forum: "KCS" v2 firmware system - Replies (2)
I watched the guide and saw there is other options such as bind output, on off toggle.
But i dont see these except reverse. Is there something wrong with the firmware for A16 rev 1.5 board?
Tried both KCS_KC868_A16_V2.1.9 and KCS_KC868_A16_V2.2.2 firmware
(12-13-2023, 02:27 AM)stanchiam Wrote: Hi,
cannot do any binding for the input to the output
please help
Question How to Use the SD Card with Raspberry Pi OS?
Posted by: sysc - 12-12-2023, 01:23 PM - Forum: KC868-Server Raspberry Pi4 local server - Replies (4)
Hello, good morning/evening everyone,
I've followed the instructions in this video to install the 64-bit Raspberry Pi OS on the eMMC.
After inserting the SD Card, I checked the '/dev' folder and used the commands 'lsblk' and 'fdisk -l', but I couldn't find any trace of it.
I tried with two different SD card models, both formatted in FAT32:
  • ShanDianSDXC 64GB
  • SanDisk SDHC 4GB
Am I forgetting something ?
Thank you in advance!
