Lesson4 - Install Home Assistant Operating System - Printable Version
+--- Forum: Home automation training courses (https://www.kincony.com/forum/forumdisplay.php?fid=18)
+--- Thread: Lesson4 - Install Home Assistant Operating System (/showthread.php?tid=1748)
Pages: 1 2 3
RE: Lesson4 - Install Home Assistant Operating System - admin - 04-25-2023
you can see here: https://www.home-assistant.io/installation/raspberrypi
just download "Raspberry Pi Imager", then you can chose home assistant OS, it's the newest.
RE: Lesson4 - Install Home Assistant Operating System - MariusM - 06-16-2023
hello, did you manage to solve the issue?
i experience the same problem on new installation of server
RE: Lesson4 - Install Home Assistant Operating System - admin - 06-16-2023
what problem?
(06-16-2023, 07:18 AM)admin Wrote: what problem?
After i done all the steps from the lesson to install home assistant on my server, when i try to reach home assistant page, the page cannot be found.
login your router find your KC868-Server IP, suggest connect your ethernet cable to your router when install.
(06-16-2023, 08:24 AM)admin Wrote: login your router find your KC868-Server IP, suggest connect your ethernet cable to your router when install.
Hello on my router shows the ip for home assistant, but im still not able to acces it. pic attached.
I have also noticed that acording to LED indicator the KC868 server is set on LAN with yellow light ( server ), is that ok ?
use these way to login:
http://homeassistant.local:8123/
http://192.168.1.10:8123/
your computer and your KC868-Server should in same one local network.
RE: Lesson4 - Install Home Assistant Operating System - MariusM - 06-17-2023
I’m on the same local network and still cannot reach home assistant.
I have plugged my tv on raspberry and it’s showing the pic . Attached.
Update problem solved !
I manged to figure the issue.
I took the laptop and server to my office and i connected the server to the network and the laptop to Wireless and everything was working smooth.
I came back to home and i tried again the same procedure at my office but still unsucessful .
I went to the store and i bought an switch which i connected to my router and i connected the server and my laptop in the same switch and everything works fine now, i'm able to acces the home assistant.
In conclusion, i don't know why but it might be a probelm with my home router when i try to acces home assistant over wireless.
Hope you find this helpfull.
RE: Lesson4 - Install Home Assistant Operating System - admin - 06-17-2023
thanks for share your result.
