Configure KC868-A8 in ESPHome - Printable Version
+--- Thread: Configure KC868-A8 in ESPHome (/showthread.php?tid=2024)
Pages: 1 2 3
RE: Configure KC868-A8 in ESPHome - fabuena - 07-08-2022
(07-08-2022, 12:07 AM)admin Wrote: not need, just different hardware version, you can see your A8 board PCB whether printed V1.4
Thank you very much!.
You have helped me a lot. Otherwise I wouldn't be able to get it started! I will recommend you to everyone I know, technical support is essential.
RE: Configure KC868-A8 in ESPHome - admin - 07-08-2022
you are welcome, KinCony will support great technical support.
RE: Configure KC868-A8 in ESPHome - juan - 10-04-2022
Hello, I am trying to configure pins A1 and A2 of a KC868-A8 board, but I do not see the configuration of these pins in the file that you have published, please can you guide me to configure them in ESPhome
Thanks in advance
RE: Configure KC868-A8 in ESPHome - admin - 10-04-2022
# Example configuration entry
- platform: adc
pin: 34
update_interval: 10s
attenuation: 11db
- platform: adc
pin: 35
attenuation: 11db
RE: Configure KC868-A8 in ESPHome - land88 - 11-16-2022
Hi,
I would like to configure an input for count my water with pulse_counter with a KC868-a8, I Have a contact dry between GND and Input 0, with a Binary_sensor, it's ok , but I can't count it with ESPHOME in Home Assistant with a sensor.
I Think I don't have the correct PIN, I Try all from 0 to 39, But Nothing...
Do you have an idea ?
Thanks
This is my configuration in HA :
platform: ESP32
board: esp32dev
sda: 4
scl: 5
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk_mode: GPIO17_OUT
phy_addr: 0
# Optional manual IP
manual_ip:
static_ip: 192.168.0.199
gateway: 192.168.0.1
subnet: 255.255.255.0
pcf8574:
- id: 'pcf8574_hub_output'
address: 0x24
- id: 'pcf8574_hub_input'
address: 0x22
- platform: pulse_counter
number: 21
mode:
input: true
pullup: true
RE: Configure KC868-A8 in ESPHome - admin - 11-16-2022
digital input 1-8 can use for dry contact sensor. but whether ESPHome can calculate the pulse number, i have not tested. if ESPHome support and make sure what your water sensor pulse frequency, whether esp32 gpio speed fast enough.
(11-16-2022, 12:48 PM)admin Wrote: digital input 1-8 can use for dry contact sensor. but whether ESPHome can calculate the pulse number, i have not tested. if ESPHome support and make sure what your water sensor pulse frequency, whether esp32 gpio speed fast enough.
For digital input it's simple, it's a binary_sensor and the platform is - platform: gpio and pin is 0,1, 2....
But for   - platform: pulse_counter what is the way to configure the PIN ? 0,1,2 doesn't oK
Who can have a configuration for pulse_counter on K868-A8 on Home assistant ?
Thanks
Binary sensor -> simple
pcf8574:
    address: 0x24
    address: 0x22
      pcf8574: pcf8574_hub_input
      # Use pin number 0
      # One of INPUT or OUTPUT
      mode: INPUT
      inverted: false
      # Use pin number 0
      number: 1
      mode: INPUT
      inverted: false
But for pulse_counter, for input 0,1,2,3.... ?
    update_interval: 2s
      number: 21
      mode:
        input: true
        pullup: true
https://esphome.io/components/sensor/pulse_counter.html
here ESPHome showed MAX can use 8 channel for counter. maybe you need to set "count_mode". A8's input by Optocoupler circuit, so check your sensor pulse speed, whether is too fast.
(11-16-2022, 02:59 PM)admin Wrote: https://esphome.io/components/sensor/pulse_counter.html
I know this article, but that doesn't explain which pin is for input 0, 1, etc
For Pin12 by exemple, what is the real input on K868-A8 ?
I have only one Counter to install, I put it between GND and Input 0, but how to configure it ? PIN 12 : Nothing....
Thanks
RE: Configure KC868-A8 in ESPHome - admin - 11-17-2022
i think maybe you can't connect directly by digital input of A8, because A8's digital input use by PCF8574 IIC extend chip, so i asked you what your water pulse sensor's speed, PCF8574 refresh input port need time.
you can try to connect with these ports:
DS18B20/DHT11/DHT21/LED strip -1: GPIO14
DS18B20/DHT11/DHT21/LED strip -2: GPIO13
DS18B20/DHT11/DHT21/LED strip -2: GPIO32
DS18B20/DHT11/DHT21/LED strip -2: GPIO33
such as connect with GPIO14, it's connect with ESP32 pin directly, just have a pull up resistance.
