[Arduino IDE demo source code for KC868-A32]--#08-Ethernet_LAN_Web_server - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A32/A32 Pro (https://www.kincony.com/forum/forumdisplay.php?fid=27) +--- Thread: [Arduino IDE demo source code for KC868-A32]--#08-Ethernet_LAN_Web_server (/showthread.php?tid=2226) Pages:
1
2
RE: [Arduino IDE demo source code for KC868-A32]--#08-Ethernet_LAN_Web_server - admin - 03-08-2023 ok RE: [Arduino IDE demo source code for KC868-A32]--#08-Ethernet_LAN_Web_server - tugalsan - 04-03-2023 Hello, When i compile and upload the code. I am getting below error: Code: rst:0x1 (POWERON_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)On internet, forums tells me to test the Lan module with the code below: https://github.com/espressif/arduino-esp32/blob/1.0.3-rc1/libraries/WiFi/examples/ETH_LAN8720/ETH_LAN8720.ino Here is the result: Code: rst:0x1 (POWERON_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)This site tels a very complex things about worng pins and such to create the bug again. https://github.com/espressif/arduino-esp32/issues/3734 Can you reproduce the problem, so that you may have a solution for this. Because I cannot use Lan, I have to connect through usb cable ![]() Here is my code: github RE: [Arduino IDE demo source code for KC868-A32]--#08-Ethernet_LAN_Web_server - admin - 04-12-2023 can you download our "KCS" firmware for a test? https://www.kincony.com/forum/showthread.php?tid=2764 RE: [Arduino IDE demo source code for KC868-A32]--#08-Ethernet_LAN_Web_server - tugalsan - 04-17-2023 (04-12-2023, 06:10 AM)admin Wrote: can you download our "KCS" firmware for a test? I uploaded it but could not connect the ip. may be it is a lan cofiguration issue. I will try again as soon as i will have time. thank you for the support. RE: [Arduino IDE demo source code for KC868-A32]--#08-Ethernet_LAN_Web_server - admin - 04-17-2023 ok RE: [Arduino IDE demo source code for KC868-A32]--#08-Ethernet_LAN_Web_server - Jora - 05-23-2024 7:42:44.620 -> rst:0x1 (POWERON_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)07:42:44.620 -> configsip: 0, SPIWP:0xee 07:42:44.620 -> clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 07:42:44.620 -> mode IO, clock div:107:42:44.671 -> load:0x3fff0030,len:1184 07:42:44.671 -> load:0x40078000,len:13260 07:42:44.671 -> load:0x40080400,len:3028 07:42:44.671 -> entry 0x400805e4 07:42:44.933 -> 07:42:44.933 -> Starting WebServer on NodeMCU_32S with ETH_PHY_LAN8720 07:42:44.973 -> WebServer_WT32_ETH01 v1.5.1 for core v2.0.0+ 07:42:45.977 -> E (1023) esp.emac: emac_esp32_init(357): reset timeout 07:42:45.977 -> E (1023) esp_eth: esp_eth_driver_install(214): init mac failed 07:47:29.087 -> E (1023) esp.emac: emac_esp32_init(357): reset timeout 07:47:29.087 -> E (1023) esp_eth: esp_eth_driver_install(214): init mac failed Can U explain step by step where our problem is? We can tray bin file? RE: [Arduino IDE demo source code for KC868-A32]--#08-Ethernet_LAN_Web_server - admin - 05-23-2024 do you using KC868-A32? make sure you have set the ethernet LAN8720 chip pin define for arduino library. |
