Nitrogen/Phosphorus/kalium/Humidity/Temperature and PH Sensors - Printable Version
+--- Thread: Nitrogen/Phosphorus/kalium/Humidity/Temperature and PH Sensors (/showthread.php?tid=2301)
Pages: 1 2
RE: Nitrogen/Phosphorus/kalium/Humidity/Temperature and PH Sensors - Kross Piter - 09-21-2022
(09-20-2022, 09:15 AM)admin Wrote: KC868-A6 use SI1278 LoRA module, here is order link, that have LoRA module bundle you can chose:
https://www.aliexpress.com/item/3256804024386819.html?spm=a2g0o.store_pc_home.hotSpots_6001931402807.1&gatewayAdapt=4itemAdapt
KC868-A6 use arduino IDE to write code to ESP32, also support use visual studio by ESP32.
Have someone here tried these?
RE: Nitrogen/Phosphorus/kalium/Humidity/Temperature and PH Sensors - admin - 09-22-2022
https://www.kincony.com/forum/forumdisplay.php?fid=22
here are some demo source code for LoRA.
RE: Nitrogen/Phosphorus/kalium/Humidity/Temperature and PH Sensors - subas - 09-26-2022
Dear Admin.
Apologies there is a change in plan. please find the plan system that now required the sensors to be RS485 compatible, GPS data, and 4G LTE. Data obtained from RS485 Modbus is sent to the IOT cloud via 4G LTE together with GPS data so that that particular Sensor will be shown on Google Maps. Please see Plan.jpg diagram
Need your advice on what is needed from your products that can help do all of this?
Regards
Subas
RE: Nitrogen/Phosphorus/kalium/Humidity/Temperature and PH Sensors - admin - 09-26-2022
if must use 4G, suggest use KC868-A8S, let sensor connnect to A8S by RS485, it have 4G module, can send sensor data to your own cloud server. next week when we have free time, maybe we can write a sample arduino code and take a video tour for it.
RE: Nitrogen/Phosphorus/kalium/Humidity/Temperature and PH Sensors - subas - 09-29-2022
(09-26-2022, 01:31 PM)admin Wrote: if must use 4G, suggest use KC868-A8S, let sensor connnect to A8S by RS485, it have 4G module, can send sensor data to your own cloud server. next week when we have free time, maybe we can write a sample arduino code and take a video tour for it.
Dear Admin.
Thank you for the technical advice.
If possible, each LoRa node user with Rs485 bus.
This will connect to a LoRaWan Gateway at the office.
We can save money/cost using LoRa Gateway instead of 4G at each node. For farmers paying data for 4G to expensive.
We need to make a video best to do:
1. Code for LoRa Node read sensors using RS485 and send data to LoRaWan Gateway.
2. LoRaWAN Gateway connects to the internet in the office and sends all Node Sensor data to any IoT Cloud Server.
3. How to create Graph and Sensor parameters to display the data in the IoT Cloud Server.
Item No 1 above the circuit board must be small so easy to install at the field.
