TUYA_ESP32_Adapter arduino source code 7.1 -support TCP connection - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-ATC / Tuya adapter V2 (https://www.kincony.com/forum/forumdisplay.php?fid=32) +--- Thread: TUYA_ESP32_Adapter arduino source code 7.1 -support TCP connection (/showthread.php?tid=2339) Pages:
1
2
RE: TUYA_ESP32_Adapter arduino source code 7.1 -support TCP connection - athxp - 07-05-2024 hi, I purchased two esp32 tuya modules to connect my two h32Ls. go configured as per the YouTube video, LED 1 and LED 2 light up only on one module. the second turns on LED 1 and LED 3. Furthermore, I can't find the device from the Tuya app. Thank you RE: TUYA_ESP32_Adapter arduino source code 7.1 -support TCP connection - admin - 07-05-2024 can you take a video of your problem then send to whatsapp number: +86-15381188302 RE: TUYA_ESP32_Adapter arduino source code 7.1 -support TCP connection - athxp - 07-06-2024 I have only telegram, do you have a contact for that? RE: TUYA_ESP32_Adapter arduino source code 7.1 -support TCP connection - admin - 07-07-2024 telegram: +8615381188302 @kincony RE: TUYA_ESP32_Adapter arduino source code 7.1 -support TCP connection - athxp - 07-12-2024 HI, I found the solution: ALL the sensors on the phone, GPS, Bluetooth, WiFi must be activated. so the devices were found immediately. RE: TUYA_ESP32_Adapter arduino source code 7.1 -support TCP connection - admin - 07-13-2024 good, thanks share your result. |
