KC868-A16S configure yaml for ESPhome - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A16S (https://www.kincony.com/forum/forumdisplay.php?fid=47) +--- Thread: KC868-A16S configure yaml for ESPhome (/showthread.php?tid=2789) Pages:
1
2
RE: KC868-A16S configure yaml for ESPhome - wodgrob - 12-17-2023 Please tell me an example of the code for working with the GSM module in ESPhome (homeassistant) RE: KC868-A16S configure yaml for ESPhome - admin - 12-18-2023 ESPHome not support 4G SIM7600 moudle directly, it only support SIM800L 2G module. here is details: https://esphome.io/components/sim800l.html RE: KC868-A16S configure yaml for ESPhome - djsomi - 01-15-2024 Hi All, Is there a way to use the analog inputs to control the relays, without a software solution behind? It is working fine with Home Assistant, but for example a centralized light control it would be essential to fallback electronics only if a network outage occurs or sever is unavailable. Thanks! RE: KC868-A16S configure yaml for ESPhome - admin - 01-15-2024 you can download KCS firmware, make IFTTT command , let analog value to control relay output. here is KCS online guide: https://www.kincony.com/esp32-kcsv2-firmware.html then you can integrate A16S board to home assistant by MQTT, so that KCS and home assistant can work at the same time. RE: KC868-A16S configure yaml for ESPhome - djsomi - 01-16-2024 (01-15-2024, 10:47 PM)admin Wrote: you can download KCS firmware, make IFTTT command , let analog value to control relay output. here is KCS online guide: https://www.kincony.com/esp32-kcsv2-firmware.html Thank you very much, I will check it. Or maybe code it in ESPHome like this: Do you have any consideration? binary_sensor: - platform: gpio name: "a16s-input1" pin: pcf8574: pcf8574_hub_in_1 number: 0 mode: INPUT inverted: true on_press: - switch.toggle: relay01 switch: - platform: gpio name: "a16s-output1" pin: pcf8574: pcf8574_hub_out_1 number: 0 mode: OUTPUT inverted: true id: relay01 Need to add for every channel, with a counter unique relay ID. RE: KC868-A16S configure yaml for ESPhome - admin - 01-17-2024 yes, i suggest you only use ESPHome is enough, not need to use KCS. RE: KC868-A16S configure yaml for ESPhome - Rumlak - 06-10-2024 Can the Digital inputs be used for things other than just binary sensors? RE: KC868-A16S configure yaml for ESPhome - admin - 06-10-2024 what function you want to use? mainly use for binary sensor type. RE: KC868-A16S configure yaml for ESPhome - alankrit0113 - 09-04-2024 Hi, everytime I try to upload ESPHOME in the A16S board it shows an error while connecting through serial port. I've attached the screenshot here. Please advise. Also if I try to connect through LAN connections it requires OTA password. Could you please provide that too.? RE: KC868-A16S configure yaml for ESPhome - admin - 09-04-2024 take a photo, how you connected with USB-C cable. |
