A4S DIMMER - Printable Version
+--- Thread: A4S DIMMER (/showthread.php?tid=2918)
Pages: 1 2
RE: A4S DIMMER - mark2023 - 05-18-2023
I have tried 2 different bulbs and they are both dimmable.
See attached photos you can see where I have circled in red.
Also why does the led still light after the input is off?
RE: A4S DIMMER - admin - 05-18-2023
This is a compatibility issue with the drive. You may need to switch to a different type of drive for your lamp.
When you say "drive" do you mean "driver"? The SSR is what I purchased from your store. If my bulbs are not compatible what bulbs do you recommend that work with your SSR? Or can you recommend a different SSR that will work with any dimmable bulbs.
yes "drive" means "SSR" product or other Driver
next week, we find a bulb as similar as yours have a test, then feedback to you.
RE: A4S DIMMER - mark2023 - 05-23-2023
Hello have you done any testing with the SSR and a bulb? I have tried several bulbs even a Philips non flicker bulb and they ar still staying alight when the output is off. I also get flicker at low dim.
I need to resolve this please
RE: A4S DIMMER - admin - 05-24-2023
can you add me whatsapp number: +86-15381188302 i send you video.
RE: A4S DIMMER - mark2023 - 05-24-2023
Added number
RE: A4S DIMMER - eligijus - 05-26-2023
try connecting this in parallel with the lamp
