Kc868-a8e - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: "KCS" firmware system (https://www.kincony.com/forum/forumdisplay.php?fid=40) +--- Thread: Kc868-a8e (/showthread.php?tid=3071) Pages:
1
2
RE: Kc868-a8e - avihay - 07-14-2023 Hey, it works, the generator turns on and off. Where can I connect the 12v battery? RE: Kc868-a8e - admin - 07-14-2023 sorry, i don't understand you, some times you said not work, now you said it work. i don't know what you want to do now? RE: Kc868-a8e - avihay - 07-15-2023 Sorry for all the confusion. Now we managed to arrange the rf433 with the generator, it works perfectly. In addition, I want to measure the volt of the 13.6 or 27 volt caravan battery Where can I connect so that I can see in the application not through esphome RE: Kc868-a8e - admin - 07-15-2023 board only support analog input port voltage range DC 0-5v. RE: Kc868-a8e - avihay - 07-15-2023 So what do you suggest I do? You're not willing to open the ic2 application for me so I can connect ina226. I don't want esphome. Or if you can give me an esphome file with all the recording options rf433 and ic2 with setting of ina226 and with an option that I can create the desired automation as I wrote RE: Kc868-a8e - admin - 07-16-2023 when voltage>27v relay ON? when voltage<13.6v relay OFF? RE: Kc868-a8e - avihay - 07-16-2023 13.6volt send rf433 generator -off 12.1v - send rf433-on generator |
