[KC868-AG PRO] Tuya and scenes - Printable Version
+--- Thread: [KC868-AG PRO] Tuya and scenes (/showthread.php?tid=3394)
Pages: 1 2
RE: [KC868-AG PRO] Tuya and scenes - zolax - 10-18-2023
(10-18-2023, 05:01 AM)KinCony Support Wrote:
(10-17-2023, 12:13 PM)zolax Wrote:
(10-17-2023, 10:23 AM)admin Wrote: if you want received 433M signal THEN turn ON relay. IF "condition" chose KC868-AG Pro --> 433M learned signal.
There is no possible to choose KC868-AG-Pro condition. There is only stuff "generated" by it like Window Pusher etc.
Maybe you could make a screen with KC868-AG-Pro selected as a condition. I have newest Tuya version on the phone.
This was possible with A4 but not with AG.
According to your question, I think you can use 3 pieces of KC868-A4, then the wireless signal will be programmed 32*3=96, we ask the tuya support ,it is not support  received RF signal to be an if command, tuya app cannot implement the IF command like KC868-A4.
Understand but A4 has only 4 output (have to use this output in tuya), need 16 virtual output on each device so will have 3x16 outputs. I already tried to put firmware from A16 to A4 but it doens't work. Can you help with this?
RE: [KC868-AG PRO] Tuya and scenes - KinCony Support - 10-19-2023
I don't think I can implement your function: because tuya app does not support learning RF signals as a condition to interact with other functions.
 The current scheme is to replace the curtain motor with a 220V motor and use the relay output of KC868-A32 to control the curtain motor
RE: [KC868-AG PRO] Tuya and scenes - zolax - 10-19-2023
I'm 100% sure it will work because already tested it in KC868-A4. I did if-then using your www menu: for example if recived=signal_1 then set output_1=0 ; if recived=signal_2 set output_1=1. After this I do if-then condition in tuya for example if output_1=0 then close actuator 0 etc. It works with 4 actuators but I need 40.
RE: [KC868-AG PRO] Tuya and scenes - KinCony Support - 10-20-2023
(10-17-2023, 12:13 PM)zolax Wrote: There is no possible to choose KC868-AG-Pro condition. There is only stuff "generated" by it like Window Pusher etc.
i think you can use KC868-A32,it have 32CH outputs  you can use two  KC868-A32 module.the solution is AG-pro or KC868-A4 use KCS firmware,and  set the ifttt command,if receive RF then send http command to KC868-A32 to open relay1,then you can do the if-then condition in tuya like you said " if output_1=0 then close actuator 0 "
RE: [KC868-AG PRO] Tuya and scenes - zolax - 10-20-2023
(10-18-2023, 05:01 AM)KinCony Support Wrote: According to your question, I think you can use 3 pieces of KC868-A4, then the wireless signal will be programmed 32*3=96, we ask the tuya support ,it is not support  received RF signal to be an if command, tuya app cannot implement the IF command like KC868-A4.
Yes can use KC868-A32 but I don't need hardware outputs, just virtual to software. So the question is it is possible to run KC868-A32 firmware on KC868-A4  hardware?
