Unresponsive KC868-A16 - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A16 (https://www.kincony.com/forum/forumdisplay.php?fid=25) +--- Thread: Unresponsive KC868-A16 (/showthread.php?tid=4122) Pages:
1
2
RE: Unresponsive KC868-A16 - NewONE - 01-20-2024 good day sir, i will try to install KCS SOFTWARE first if my A16 board will response ok. then i will install the ESP home yaml after if successful. i will inform you sir. thank you. RE: Unresponsive KC868-A16 - admin - 01-20-2024 ok RE: Unresponsive KC868-A16 - NewONE - 01-21-2024 Good day sir, i have tested the KCS firwmware for myA16 and the ethernet port was ok, i tested the output, but as soon as i uploaded the ESPHOME yaml file on my homeassistant the ETHERNET port turns OFF or it becomes disabled. i dont know why. Can you check the pictures below, check if the CODE for the LAN Ethernet port is correct? I used the same code for the LAN before and it works.. Maybe there is a correct CODE for LAN Ethernet port. Please check and advise sir. Thank you RE: Unresponsive KC868-A16 - admin - 01-21-2024 here is ESPhome config yaml for A16 board, you just directly to use: Code: esphome: RE: Unresponsive KC868-A16 - benpot1992 - 03-03-2024 I bought new board KC868-A16 in version 1.6 and i want install KCS SOFTWARE V2.2.2 in this board according online guide, but I have the following errors. Please help me. RE: Unresponsive KC868-A16 - admin - 03-04-2024 before you download firmware, you should remove RF433MHz receiver module from your A16 PCB. can you take a photo of your working A16 PCB. RE: Unresponsive KC868-A16 - benpot1992 - 03-07-2024 Now it's OK, thank you. What's the easiest way to connect it with a home assistant? RE: Unresponsive KC868-A16 - admin - 03-07-2024 if you want A16 integrate to home assistant, use by ESPHome is easiest. |
