Rs485 - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KinCony Server-Mini / Server-16 Raspberry Pi4 relay module (https://www.kincony.com/forum/forumdisplay.php?fid=53) +--- Thread: Rs485 (/showthread.php?tid=5790) Pages:
1
2
RE: Rs485 - Savino - 06-29-2024 (06-29-2024, 01:34 AM)admin Wrote: download KCS firmware to A6 board, enable RS485 using MODBUS-RTU. just login KCS webpage to set. Sorry, I'm not using KCS firmware for the A6 board. I flashed the A6 board with a basic yaml file downloaded from ESP Home support pages. So I only need to add to the yaml file the correct lines in order to:
Could you show me the details? Thanks in advance RE: Rs485 - admin - 06-29-2024 i already sent you video tour link, just do as that . RE: Rs485 - Savino - 07-07-2024 (06-27-2024, 10:31 PM)admin Wrote: if you are first time to use server-mini, you need to enable serial port for CM4, here is details : I was able to find the config.txt file on my Sd card and set enable_uart=1 Unfortunately trying to disable Linux Uart console I go to the homeassistant terminal and when I try the command sudo raspi-config I get the message command not found. Any hint for this step? RE: Rs485 - admin - 07-07-2024 where you installed home assistant software? raspberry pi? which home assistant firmware you have installed? RE: Rs485 - Savino - 07-08-2024 (07-07-2024, 11:13 PM)admin Wrote: where you installed home assistant software? raspberry pi? home assistant installed onto KC868-Server Mini with CM4 and SD card. the firmware installed was haos_rpi4-64-7.4.img At the moment I have Home Assistant Core 2024.7.0 Supervisor 2024.06.2 Operating System 12.4 Frontend 20240703.0 RE: Rs485 - admin - 07-08-2024 can you take a video of your problem, when you input "sudo raspi-config" have error. send video to whatsapp number: +86-15381188302 |
