DOA KC868-A16 - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: "KCS" firmware system (https://www.kincony.com/forum/forumdisplay.php?fid=40) +--- Thread: DOA KC868-A16 (/showthread.php?tid=6125) Pages:
1
2
RE: DOA KC868-A16 - admin - 07-23-2024 Your blue relay's A1 should connect to GND, not 12V. RE: DOA KC868-A16 - luis15pt - 07-23-2024 Made the change but still can not get the relay to work, as previously stated i do think its something to do with my tasmota as when i turn the outputs on or off, no lights on the pcb light up. RE: DOA KC868-A16 - admin - 07-23-2024 take a photo how you wire now. suggest you download KCS firmware for a testing firstly. if KCS firmware work well, that means hardware PCB is well, then check with your tasmota. RE: DOA KC868-A16 - luis15pt - 07-23-2024 So i tried KCS firmware, im not to sure how to manually force the outputs but using IFTTT and turning Output 1 Off and On, the relay works. Which means it must be something to do with Tasmota firmware, can you attach a known working firmware for the KC868_A16 RE: DOA KC868-A16 - admin - 07-23-2024 how to use tasmota with KC868-A16, you can check with this link: https://www.kincony.com/forum/showthread.php?tid=1715 |
