KC-868 A16 output strange behaviour - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A16 (https://www.kincony.com/forum/forumdisplay.php?fid=25) +--- Thread: KC-868 A16 output strange behaviour (/showthread.php?tid=6258) Pages:
1
2
RE: KC-868 A16 output strange behaviour - admin - 08-02-2024 ok, good. RE: KC-868 A16 output strange behaviour - Linnalahti - 08-12-2024 Can I connect ON/OFF switch parralel with A16 output if I want manual override output state? RE: KC-868 A16 output strange behaviour - admin - 08-12-2024 NO, it's not a good way. RE: KC-868 A16 output strange behaviour - Linnalahti - 08-14-2024 (08-12-2024, 11:07 PM)admin Wrote: NO, it's not a good way. Can you give an other solution? RE: KC-868 A16 output strange behaviour - admin - 08-14-2024 switch buttons should connect to digital input ports, then make IFTTT command for AUTOMATION. RE: KC-868 A16 output strange behaviour - Linnalahti - 08-15-2024 (08-14-2024, 12:57 PM)admin Wrote: switch buttons should connect to digital input ports, then make IFTTT command for AUTOMATION. But if board is broken! or other SW error? Is disconnect output connector only way to manualy get heating on. RE: KC-868 A16 output strange behaviour - admin - 08-15-2024 do you use a extend relay with A16? if YES, you can manual control the extend relay's coin. |
