How to control RGBW 5pin led strip with A16 controller - Printable Version
+--- Thread: How to control RGBW 5pin led strip with A16 controller (/showthread.php?tid=6892)
Pages: 1 2
RE: How to control RGBW 5pin led strip with A16 controller - MariusM - 12-20-2024
I have the following case:
I have KC868 server, i configured the GPIO for 5 V led strip - all working fine.
I have K868 AP , i configured for RGBW led strip 24 V - all led's working fine.
The issue is that when i turn on the both Led strips 24 V and the 5V data led strip , the 5 V data strip start to fliker when changing the colours.
Do you have any idea why KC868 AP influences the server GPIO and makes all leds frome 5 V strip to fliker ?
The fliker is more like all leds are going crazy during changing the colours.
RE: How to control RGBW 5pin led strip with A16 controller - admin - 12-21-2024
take a photo how you wire your board.
RE: How to control RGBW 5pin led strip with A16 controller - MariusM - 12-22-2024
(12-21-2024, 12:28 AM)We admin Wrote: take a photo how you wire your board.
The power supply negative - from 12V and 5V are connected together.
On right side is the 24V power supply.
RE: How to control RGBW 5pin led strip with A16 controller - admin - 12-22-2024
KC868-Server and KC868-AP all work with DC24V power supply?
RE: How to control RGBW 5pin led strip with A16 controller - MariusM - 12-23-2024
(12-22-2024, 11:47 PM)admin Wrote: KC868-Server and KC868-AP all work with DC24V power supply?
No, the server is 12 V , kc-868-AP is at 24V
RE: How to control RGBW 5pin led strip with A16 controller - admin - 12-23-2024
KC868-Server support DC12-24. suggest you use one DC24V power supply. not need to use DC12v power supply.
RE: How to control RGBW 5pin led strip with A16 controller - MariusM - 12-24-2024
I changed to 24V server and AP , but still same symptoms.
I also connected the negative - from 5V supply to negative - 24 V.
It’s strange because the 5V led strip works fine only if I turn off the RGBW from KC868-AP.
When RBGW is turned on and I want to change the colour of 5V strip led , the 5V strip act haotic on colours.
RE: How to control RGBW 5pin led strip with A16 controller - MariusM - 01-09-2025
(12-24-2024, 11:33 AM)MariusM Wrote: I changed to 24V server and AP , but still same symptoms.
Any help?
RE: How to control RGBW 5pin led strip with A16 controller - admin - 01-09-2025
take a video send to whatsapp number: +86-15381188302
