Unable to Turn "Off" or "ON" via KC868 CON and 32 Relay board Controller via RS232 - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: Development (https://www.kincony.com/forum/forumdisplay.php?fid=4) +--- Thread: Unable to Turn "Off" or "ON" via KC868 CON and 32 Relay board Controller via RS232 (/showthread.php?tid=7) Pages:
1
2
RE: Unable to Turn "Off" or "ON" via KC868 CON and 32 Relay board Controller via RS232 - subas - 10-27-2020 (10-27-2020, 02:33 PM)subas Wrote: Dear Sir. I have Tested the solution and it works if I connect to the KC868-H32B via WiFi. Why when i use the "Virtual Serial & Device Management" Vircom Application I don't see the KC868-H32Bdevice in there as compared to KC868-COL which I do see? Because i don't see the KC868-H32B how do I see the IP and port for the KC868-H32B after configuring the device if it does not appear in VirCom? RE: Unable to Turn "Off" or "ON" via KC868 CON and 32 Relay board Controller via RS232 - admin - 10-28-2020 Because B series product use new technology, not need use VirCom again. just config all network setting by website, it's easy for config, such as work in Apple MAC computer. Controller default is DHCP, you can see IP address in your router or you can use IP scan tool see the IP. this is a tool: https://www.kincony.com/download/Advanced-IP-Scanner.zip it can scan all IP address in your LAN network. I think you can see our KC868-H32B online guide firstly. All details are explained. |
