ESPhome builder 2025.2 - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KinCony AS (https://www.kincony.com/forum/forumdisplay.php?fid=64) +--- Thread: ESPhome builder 2025.2 (/showthread.php?tid=7650) Pages:
1
2
RE: ESPhome builder 2025.2 - eyevisions - 02-26-2025 @kamermcw Strange, I already had that in my yaml file as I uploaded it. And the error hasn't changed here. INFO ESPHome 2025.2.1 INFO Reading configuration /config/esphome/as.yaml... Failed config light.esp32_rmt_led_strip: [source /config/esphome/as.yaml:107] platform: esp32_rmt_led_strip id: led_ww rgb_order: GRB pin: GPIO16 num_leds: 1 This feature is not available for the IDF framework version 5. rmt_channel: 0 chipset: ws2812 name: on board light effects: - pulse: {} - pulse: name: Fast Pulse RE: ESPhome builder 2025.2 - kamermcw - 02-26-2025 It might be me, but I don't see it in your config here. RE: ESPhome builder 2025.2 - eyevisions - 03-06-2025 @kamermcw In mine yaml file i have this: esp32: board: esp32-s3-devkitc-1 framework: type: esp-idf Can you show me your yaml file that works? RE: ESPhome builder 2025.2 - kamermcw - 03-06-2025 (03-06-2025, 08:35 AM)eyevisions Wrote: @kamermcwFor the esp32 section it looks like this. Now you can leave the rmt_channel in there. esp32: board: esp32-s3-devkitc-1 framework: type: esp-idf version: 4.4.8 platform_version: 5.4.0 sdkconfig_options: CONFIG_ESP32S3_DEFAULT_CPU_FREQ_240: "y" CONFIG_ESP32S3_DATA_CACHE_64KB: "y" CONFIG_ESP32S3_DATA_CACHE_LINE_64B: "y" CONFIG_AUDIO_BOARD_CUSTOM: "y Just found another also working solution. Not sure which one is better. I am going with this one for now. Instead of putting in the version and platform _version for isp-idf, replace rmt_channel with rmt_symbols: 96 in both cases. |
