Lesson13 - integrate KC868-AG to home assistant control air conditioner by IR - Printable Version
+--- Forum: Home automation training courses (https://www.kincony.com/forum/forumdisplay.php?fid=18)
+--- Thread: Lesson13 - integrate KC868-AG to home assistant control air conditioner by IR (/showthread.php?tid=1812)
Pages: 1 2 3
RE: Lesson13 - integrate KC868-AG to home assistant control air conditioner by IR - Almhlws - 03-13-2023
thank you for your support
i try this code but not working for Gree ac
# Example configuration entry
remote_receiver:
    number: GPIO14
    mode:
      input: true
      pullup: true
  # high 55% tolerance is recommended for some remote control units
  tolerance: 55%
climate:
  - platform: greeya
    name: "Living Room AC"
    receiver_id: rcvr
RE: Lesson13 - integrate KC868-AG to home assistant control air conditioner by IR - admin - 03-13-2023
i think this you can feedback to ESPHome forum for a help is better.
RE: Lesson13 - integrate KC868-AG to home assistant control air conditioner by IR - ARSHAD - 04-24-2023
Can we use external sensor (Temperature / humidity)  to turn on/off Air Conditioner or Room Fan ?
or
any other device ? to control air conditioner
RE: Lesson13 - integrate KC868-AG to home assistant control air conditioner by IR - admin - 04-24-2023
if you have another board , such as KC868-AM connect with DS18B120 temperature sensor. your KC868-AG also is integrate to home asisstant. Then you can set AUTOMATION for that. temperature control send IR signal to air conditioner.
