KinCony-TUYA_ESP32_Adapter ESP32 arduino source code - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-ATC / Tuya adapter V2 (https://www.kincony.com/forum/forumdisplay.php?fid=32) +--- Thread: KinCony-TUYA_ESP32_Adapter ESP32 arduino source code (/showthread.php?tid=2316) |
RE: KinCony-TUYA_ESP32_Adapter ESP32 arduino source code - shayaway - 01-11-2024 Hi, Is there code available for 16 outputs: (KC868-H16) ? RE: KinCony-TUYA_ESP32_Adapter ESP32 arduino source code - admin - 01-12-2024 you can use for KC868-H16 by tcp connection, but need modify the code, because H16 only have 16 channel relay. RE: KinCony-TUYA_ESP32_Adapter ESP32 arduino source code - shayaway - 01-12-2024 (01-12-2024, 12:24 AM)admin Wrote: you can use for KC868-H16 by tcp connection, but need modify the code, because H16 only have 16 channel relay. Thanks for reply RE: KinCony-TUYA_ESP32_Adapter ESP32 arduino source code - shayaway - 03-04-2024 Hi, Is it possible to disable or delete "ALL ON" and "ALL OFF" commands on the app? RE: KinCony-TUYA_ESP32_Adapter ESP32 arduino source code - admin - 03-04-2024 sorry, can't do that. RE: KinCony-TUYA_ESP32_Adapter ESP32 arduino source code - shayaway - 03-07-2024 I have a Kincony-ESP32-Tuya adaptor with Arduino source code installed. This is connected by RS232 to KC868-H32B smart controller. I’m using Tuya Smart App and everything works OK. My question: Is it possible to modify the code to disable or delete “All On” and “All Off” commands? RE: KinCony-TUYA_ESP32_Adapter ESP32 arduino source code - admin - 03-07-2024 sure, this you can do, just delete ALL ON and ALL OFF arduino code. I though you want remove the ALL ON / ALL OFF ico button from tuya app, that can't. RE: KinCony-TUYA_ESP32_Adapter ESP32 arduino source code - shayaway - 03-09-2024 I'm not very experienced with arduino code so how do I delete ALL ON and ALL OFF from the code RE: KinCony-TUYA_ESP32_Adapter ESP32 arduino source code - shayaway - 03-26-2024 Hi, can anyone help me with this - I want to delete ALL OFF and ALL ON from arduino code. |
