New home with KinCony products - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: DIY Project (https://www.kincony.com/forum/forumdisplay.php?fid=3) +--- Thread: New home with KinCony products (/showthread.php?tid=3806) |
RE: New home with KinCony products - sebagarayco - 05-07-2024 (03-12-2024, 02:06 AM)admin Wrote: ok, no problem, just post at here. Hi Kincony, I'm working with KC868-D16, 12V PowerSupply and 12V 7W dimmer lamp. I'm using this config: - name: dimmer-2 unique_id: dimmer-2 schema: template command_topic: 'dimmer/28e5d2df6311b55XXXXXXXXX/set' state_topic: 'dimmer/28e5d2df6311b55XXXXXXXXXX/state' command_on_template: > {%- if brightness is defined -%} ,{"dimmer2":{"value":{{(brightness / 255 * 100) | int - 1}}} {%- else -%} ,'{"dimmer2":{"value":99}}' {%- endif -%} command_off_template: '{"dimmer2":{"value":0}}' What I notice is that light only changes from 0 to 20% then it's all the same as if it is at 100%. How to fix this? RE: New home with KinCony products - admin - 05-07-2024 what LED driver you are using? you can use multi meter to test D16 output GREEN terminal, whether you change 0--100% whether is 0-10v dc output RE: New home with KinCony products - sebagarayco - 06-11-2024 (05-07-2024, 10:17 PM)admin Wrote: what LED driver you are using? you can use multi meter to test D16 output GREEN terminal, whether you change 0--100% whether is 0-10v dc output Hi! I'm using one of your LED driver bought on AliExpress (12V). I've tested D16 output and it's totally accurate. When home assistant is at 50%, multimeter shows 5v, when at 100%, shows 10v. Problem is that the light only change brightness when between 0-50%, from 50% to 100% brightnes remains the same (full brightness).. Please confirm if this is accurate and how to fix: - name: dimmer-2 unique_id: dimmer-2 schema: template command_topic: 'dimmer/XXXXXXXXXXXXXXXXXXXXX/set' state_topic: 'dimmer/XXXXXXXXXXXXXXXXXXXXX/state' command_on_template: > {%- if brightness is defined -%} ,{"dimmer2":{"value":{{(brightness / 255 * 100) | int - 1}}} {%- else -%} ,'{"dimmer2":{"value":99}}' {%- endif -%} command_off_template: '{"dimmer2":{"value":0}}' state_template: > {%- if value_json.dimmer2.value == 0 -%} off {%- else -%} on {%- endif -%} brightness_template: '{{(value_json.dimmer2.value / 99 * 255)| int}}' RE: New home with KinCony products - admin - 06-12-2024 Because it is not linear in HA, you can try to adjust setting. when we have free time, we will have a look. RE: New home with KinCony products - sebagarayco - 06-12-2024 (06-12-2024, 02:42 AM)admin Wrote: Because it is not linear in HA, you can try to adjust setting. when we have free time, we will have a look. Yes please as this will determine if I can use D16 for my house and dimmer bulbs or not... Moreover, I'm not receiving notifications/emails from the forum. Is it working ok? Thread subscription is set to: Subscribe and receive email notification of new replies. RE: New home with KinCony products - sebagarayco - 07-01-2024 Hi Kincony, wonder if you had some time to take a look at previous message. I ran more tests and noticed that SSR are not operating at 220v (~160-170v instead). I tried two different in case one of them was failed. See screenshot attached. LED Driver is receiving 220v Any help? Thanks RE: New home with KinCony products - admin - 07-01-2024 let KC868-D16 dimmer output dc 0-10v, then SSR will output AC 0-220V. take a photo how you wire. suggest you add a "Resistive" load for testing. RE: New home with KinCony products - sebagarayco - 07-04-2024 (07-01-2024, 10:28 PM)admin Wrote: let KC868-D16 dimmer output dc 0-10v, then SSR will output AC 0-220V. I never see 220v and lamps turn on but work erratically. Here's a photo of the wiring. I've been testing Channel 16 with different 220v bulbs, also tested different SSR to discard but both behave the same. I notice that bulb light is not stable at low %... please help RE: New home with KinCony products - admin - 07-04-2024 when i have free time, i will take a demo video use KC868-D16 work with AC220v lamp for you. in your photo, i seen the right output terminal connect with a LED strip. No, you need add a driver to D16 output, LED strip connect with a driver. can't connect with D16 directly. RE: New home with KinCony products - drazvan2003 - 07-14-2024 Hello, i want to make my new apartment smart but i have no idea if https://shop.kincony.com/products/16ch-raspberry-pi-distribution-panel-home-assistant-node-red will be enough or i need this one https://shop.kincony.com/products/32ch-smart-distribution-panel-with-energy-monitoring. Could you help me to figure what is the best options for the below setup My setup is: 12 light switches 16 lightbulbs ( but there will be 3 pairs of 2 lights bulbs + 10 individual) 12 outlets 4 presence sensors 4 temperature sensors and probably in the future 5 roller shades Sorry for posting here but the thread that i created doesn't appear. hope its not an issue. Best regards |
