Display Relay Status on NodeRed - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: Development (https://www.kincony.com/forum/forumdisplay.php?fid=4) +--- Thread: Display Relay Status on NodeRed (/showthread.php?tid=25) |
RE: Display Relay Status on NodeRed - filiperod - 11-15-2022 (11-15-2022, 08:30 AM)admin Wrote: sure , our old customer Hi Yes, I have the motors connected directly to the KC868 board. They are fed from the 220v circuits, but have transformers inside the motor casing to convert to low DC voltage. In this case I need a RC snubber in each relay output? RE: Display Relay Status on NodeRed - admin - 11-15-2022 do you only use H32 32 channel relay output for curtain motor? RE: Display Relay Status on NodeRed - filiperod - 11-15-2022 Yes, I use a KC868-H32 to control 16 motors, 2 relays per each motor, one for up and another for down. I am using all 32 relays. RE: Display Relay Status on NodeRed - admin - 11-15-2022 ok, if only connect with curtain motor, no problem, H32B not need connect with RC snubber. you can contact with seller, do you buy H32 from our aliexpress official store? RE: Display Relay Status on NodeRed - filiperod - 11-15-2022 (11-15-2022, 09:28 PM)admin Wrote: ok, if only connect with curtain motor, no problem, H32B not need connect with RC snubber. Yes, I bought from the aliexpress store. Can you give me the contact of the seller? RE: Display Relay Status on NodeRed - admin - 11-16-2022 which aliexpress store? you can send message to kincony official store aliexpress online store. kincony.aliexpress.com |
