HC868 COLB kickstart - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KC868-HxB series Smart Controller (https://www.kincony.com/forum/forumdisplay.php?fid=2) +--- Thread: HC868 COLB kickstart (/showthread.php?tid=1066) |
HC868 COLB kickstart - leliodm - 11-07-2021 Hi, I just opened and connected by COLB. I am able to visualize the change of status of the DI input ports from the smart board controller app. I would like to know 1. what is the procedure to update the firmware step by step - I could not find the right thread in the forum, sorry if I missed something 2. I cannot connect to the web interface where to configure the MQTT server - I can only see the interface as attached to this message. Any help is welcome! Thanks Lee RE: HC868 COLB kickstart - KinCony Support - 11-08-2021 (11-07-2021, 09:09 PM)leliodm Wrote: Hi, You need connect a network cable ,then find the IP of ethernet and open your browser, you can get the parameters. Like this: |
