How to use TCP Server and TCP Client work mode for your own software - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: Development (https://www.kincony.com/forum/forumdisplay.php?fid=4) +--- Thread: How to use TCP Server and TCP Client work mode for your own software (/showthread.php?tid=1081) |
How to use TCP Server and TCP Client work mode for your own software - admin - 11-09-2021 1: Ethernet work mode = "TCP Server" controller is a "server", your software is "client". 2: WiFi work mode = "TCP Server" controller is a "server", your software is "client". 3: Ethernet work mode = "TCP Client" your software is a "server", controller is "client". when power on, controller will auto connect to your software by ethernet. just "client" will auto connect to "server". 4: WiFi work mode = "TCP Client" instead by MQTT in new firmware your software is a "server", controller is "client". when power on, controller will auto connect to your software by wifi. just "client" will auto connect to "server". 5: Ethernet work mode = "TCP Client"; WiFi work mode = "TCP Server" A. your software is a "server", controller is "client". when power on, controller will auto connect to your software by ethernet. B. controller is a "server", you software is "client". |
