KC-868-H32BS with 220 v Load relay 12 v dc - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: DIY Project (https://www.kincony.com/forum/forumdisplay.php?fid=3) +--- Thread: KC-868-H32BS with 220 v Load relay 12 v dc (/showthread.php?tid=1174) |
KC-868-H32BS with 220 v Load relay 12 v dc - ahmed - 11-19-2021 Can i use this module for controlling the KC-868-H32BS for controlling 220 volt load using 10A relay with 12 V DC coil from local market, see the attached photo. RE: KC-868-H32BS with 220 v Load relay 12 v dc - admin - 11-19-2021 no problem. just your relay work coin is DC12V. RE: KC-868-H32BS with 220 v Load relay 12 v dc - ahmedk4444@yahoo.com - 02-17-2022 Iis any way to use the KC-868-H32BS as KC-868-H32B to connect my 220 v load to the output of controller since the liad is 3A or less? RE: KC-868-H32BS with 220 v Load relay 12 v dc - admin - 02-18-2022 just need add extend relay module, such as KC868-E16, because KC868-H32BS is 32 channel MOSFET output. |
