Is the KC868- D8 dimming unit can be controlling the brightness (dimming) good withS - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: DIY Project (https://www.kincony.com/forum/forumdisplay.php?fid=3) +--- Thread: Is the KC868- D8 dimming unit can be controlling the brightness (dimming) good withS (/showthread.php?tid=1175) |
Is the KC868- D8 dimming unit can be controlling the brightness (dimming) good withS - ahmed - 11-19-2021 Is the KC868- D8 dimming unit can be controlling the brightness (dimming) good with SSR relay? The Kincony youtube clip is showing the led dimming driver is more smoothly dimming than the SSR. Can you please indicate the type of SSR that can be used with Is the KC868- D8 dimming unit to control perfectly the brightness and input and output voltage range dc to ac ? This is attached one are available in local market SSR-40 DA-H i/p 3-32VDC and o/p 90-480 V A/C RE: Is the KC868- D8 dimming unit can be controlling the brightness (dimming) good withS - admin - 11-19-2021 this question replied in another question topic. |
