integrate home assistant by http url command sample - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: Development (https://www.kincony.com/forum/forumdisplay.php?fid=4) +--- Thread: integrate home assistant by http url command sample (/showthread.php?tid=1316) |
integrate home assistant by http url command sample - admin - 12-08-2021 here is a http url command integrate with home assistant config demo sample for button5 (thanks for our customer supplied the config code) - platform: command_line switches: poolbtn5: command_on: "curl -k --silent 'http://192.168.1.136/sw_ctl.cgi?Relay05=ON&postpwd=12345'" command_off: "curl -k --silent 'http://192.168.1.136/sw_ctl.cgi?Relay05=OFF&postpwd=12345'" command_state: curl -k --silent 'http://192.168.1.136/sw_ctl.cgi?RelayFF=RD&postpwd=12345' | grep -oP "(?<=btn5)(.*)(?=btn6)" value_template: '{{"ON" in value}}' friendly_name: poolbtn5 RE: integrate home assistant by http url command sample - engmohades - 12-11-2021 how to use these integrate home assistant by http url command sample? RE: integrate home assistant by http url command sample - admin - 12-11-2021 we suggest integrate home assistant by MQTT. if you really want integrate with http, you can see the above configure of yaml file. |
