KC868-A16 ESP32 I/O pin define - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A16 (https://www.kincony.com/forum/forumdisplay.php?fid=25) +--- Thread: KC868-A16 ESP32 I/O pin define (/showthread.php?tid=1666) |
KC868-A16 ESP32 I/O pin define - admin - 01-14-2022 #define ANALOG_A1 36 #define ANALOG_A2 34 #define ANALOG_A3 35 #define ANALOG_A4 39 IIC SDA:4 IIC SCL:5 Relay_IIC_address 0x24 Relay_IIC_address 0x25 Input_IIC_address 0x21 Input_IIC_address 0x22 DS18B20/DHT11/DHT21/LED strip -1: 32 DS18B20/DHT11/DHT21/LED strip -2: 33 DS18B20/DHT11/DHT21/LED strip -2: 14 RF433MHz wireless receiver: 2 RF433MHz wireless sender: 15 Ethernet (LAN8720) I/O define: #define ETH_ADDR 0 #define ETH_POWER_PIN -1 #define ETH_MDC_PIN 23 #define ETH_MDIO_PIN 18 #define ETH_TYPE ETH_PHY_LAN8720 #define ETH_CLK_MODE ETH_CLOCK_GPIO17_OUT RS485: RXD:16 TXD:13 RE: KC868-A16 ESP32 I/O pin define - Olsen@HuaHin - 03-12-2023 (01-14-2022, 11:29 PM)admin Wrote: #define ANALOG_A1 36 Hi, I am new to Kincony and the Arduino IDE. Working on a Standalone smart home control with KBOX Smart So, this is the complete I/O pin configuration I need to use in my Arduino Sketch to be able to run? Do you have a diagram showing the above I/O's? RE: KC868-A16 ESP32 I/O pin define - admin - 03-12-2023 if you want to use KBOX phone app, you can download "KCS" firmware, so that can directly to use. we have video tour about "KCS", you can see it on our YouTube channel. RE: KC868-A16 ESP32 I/O pin define - Olsen@HuaHin - 03-12-2023 Thanks for the reply, will check out the mentioned video. What about my question regarding the I/O diagram and configuration? RE: KC868-A16 ESP32 I/O pin define - admin - 03-13-2023 "KCS" video tour: https://youtu.be/gJTUb1SGnII diagram for KC868-A16: https://www.kincony.com/download/KC868-A16-schematic.pdf RE: KC868-A16 ESP32 I/O pin define - zashiv - 05-15-2023 Is it possible to get PWM signal from GPIOs marked as HT1, HT2 and HT3 to connect it to my dimmer? If so, what would be esphome configuration? RE: KC868-A16 ESP32 I/O pin define - admin - 05-16-2023 no, some specific pins can use for PWM, not any ESP32 pins. you need to check with ESP32 datasheet. |
