KC868-H32BS v 1.44 x PZEM 017 DC - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KC868-HxB series Smart Controller (https://www.kincony.com/forum/forumdisplay.php?fid=2) +--- Thread: KC868-H32BS v 1.44 x PZEM 017 DC (/showthread.php?tid=1678) |
KC868-H32BS v 1.44 x PZEM 017 DC - rodrigomallmann - 01-28-2022 Hello, I would like to know if it is possible to use the RS485 port to receive the reading data from a pzem 017 dc to integrate with the Home Assistant using MQTT. Thanks. RE: KC868-H32BS v 1.44 x PZEM 017 DC - admin - 01-28-2022 no, the RS485 of H32BS is "slave" mode, use for integrate by other "master" device. RE: KC868-H32BS v 1.44 x PZEM 017 DC - rodrigomallmann - 01-31-2022 OK, Thanks. RE: KC868-H32BS v 1.44 x PZEM 017 DC - hentes - 02-01-2022 (01-31-2022, 04:55 PM)rodrigomallmann Wrote: OK, Thanks. Hi. Probably it's possible with COLB, but only with Node-Red. Sadly there is no flow available for this. I have a Kincony energy meter and a COLB device, the data flows in to COLB but cannot use in Home Assistant without the above mentioned Node-Red flow. RE: KC868-H32BS v 1.44 x PZEM 017 DC - admin - 02-01-2022 if you use Node-Red on raspberry pi, i suggest you use a USB-RS485 adapter, let pi connect with kincony power energy meter directly, the meter use by MODBUS protocol , easy to integrate with home assistant, not need via COLB. |
