How to use RF command on KC868 - H32BS controller - Printable Version
+--- Thread: How to use RF command on KC868 - H32BS controller (/showthread.php?tid=1684)
How to use RF command on KC868 - H32BS controller - autind - 02-05-2022
 How to use and configure RF command reception and transfer for the H32BS controller?
RE: How to use RF command on KC868 - H32BS controller - admin - 02-05-2022
see this video tour, how to learn RF signal from RF remoter: https://youtu.be/4_YDX3bGI64
RE: How to use RF command on KC868 - H32BS controller - autind - 02-05-2022
When I use your controller, when recording the buttons are all 16 keys captured automatically?
Is it possible to use another type of control?
In this case, how is the addressing of the relay to be activated?
When I use your controller, when recording the buttons are all 16 keys captured automatically? Yes, just press any key, 16 keys will be all captured.
mainly only use by our remoter. or you can use other "copy" type remoter, see here video tour: https://youtu.be/5OQL4241gLw
every remoter have different address, this address can set on the PCB board of remoter.
RE: How to use RF command on KC868 - H32BS controller - autind - 02-06-2022
(02-05-2022, 02:41 AM)admin Wrote: When I use your controller, when recording the buttons are all 16 keys captured automatically?    Yes, just press any key, 16 keys will be all captured.
Ok, thanks you....
RE: How to use RF command on KC868 - H32BS controller - admin - 02-07-2022
you are welcome
