A32 module planed? - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A32/A32 Pro (https://www.kincony.com/forum/forumdisplay.php?fid=27) +--- Thread: A32 module planed? (/showthread.php?tid=1721) |
A32 module planed? - janosch1337 - 02-28-2022 hey, i read here in forum that a module with 32 I/O is planed. so i have some questions ![]() is it planed with relays or mosfets? i2c possible? release date? 12V or 24V? which other additional inputs are planed? (analog in/out etc...) greetings RE: A32 module planed? - admin - 02-28-2022 A32 is design for 32 channel relays. i2c extend interface on the board. serial port for Nextion display interface. 4 channel analog input. A32 work voltage is DC12v, but relay can work for MAX 270V/10A A32 will release after about 2 weeks. RE: A32 module planed? - janosch1337 - 03-18-2022 Hi, i saw A32 is now available. Nice! is there no solution for temperature sensors? led stripes? RE: A32 module planed? - admin - 03-18-2022 serial port GPIO two pins you can use for DS18B20 temperature sensor or WS2812B LED strip. |
