Dimmer D8 - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KC868-HxB series Smart Controller (https://www.kincony.com/forum/forumdisplay.php?fid=2) +--- Thread: Dimmer D8 (/showthread.php?tid=1746) |
Dimmer D8 - hentes - 03-12-2022 Hello Today I have powered off the server which runs Home Assistant and Mosquitto Broker for maintenance. I have several wall switches connected to Dimmer D8 and the Dimmer D8 work mode is set to MQTT and switcher workmode to 1 key. I have observed that without an active MQTT broker all the wall switches are unresponsive. Have to press several times to turn on/off the lights. After the MQTT broker gets online again the wall switches are working fine again. Could you please take a look to this problem. Thank you. RE: Dimmer D8 - admin - 03-13-2022 1 key mode need hold on the button, whether work well? can you take a video of your problem? |
