KC868-A32 ESP32 I/O pin define - Printable Version
+--- Forum: KC868-A32/A32 Pro (https://www.kincony.com/forum/forumdisplay.php?fid=27)
+--- Thread: KC868-A32 ESP32 I/O pin define (/showthread.php?tid=1771)
KC868-A32 ESP32 I/O pin define - admin - 03-23-2022
#define ANALOG_A1  GPIO39
#define ANALOG_A2  GPIO34
#define ANALOG_A3  GPIO36
#define ANALOG_A4  GPIO35
IIC Bus:A
SDA-A:GPIO15
SCL-A:GPIO13
PCF8574:U16 (relay1-8): 100 100 = 0x24
PCF8574:U32 (relay9-16): 100 101 = 0x25
PCF8574:U58 (relay17-24): 100 001 = 0x21
PCF8574:U59 (relay25-32): 100 010 = 0x22
IIC Bus:B
SDA-B:GPIO4
SCL-B:GPIO5
PCF8574:U14 (DI1-8): 100 100 = 0x24
PCF8574:U31 (DI9-16): 100 101 = 0x25
PCF8574:U56 (DI17-24): 100 001 = 0x21
PCF8574:U57 (DI25-32): 100 010 = 0x22
#define ETH_ADDR        0
#define ETH_POWER_PIN  -1
#define ETH_MDC_PIN    23
#define ETH_MDIO_PIN  18
RS485:
RXD:GPIO16
TXD:GPIO14
Extend serial port (3.3v TTL level):
RXD:GPIO33
TXD:GPIO32
RE: KC868-A32 ESP32 I/O pin define - Que - 02-12-2025
Hello i have a KC868-A32 i want to connect wiegand reader this input can you say me whats de input number ?
RE: KC868-A32 ESP32 I/O pin define - admin - 02-12-2025
the digital input can't use for wiegrand. there is serial port extender (white 4 pin socket on the PCB) , you can use these 2 free gpio for wiegand. then you can config wiegand by ESPHome or write your own arduino code.
(02-12-2025, 11:07 AM)admin Wrote: the digital input can't use for wiegrand.  there is serial port extender (white 4 pin socket on the PCB) , you can use these 2 free gpio for wiegand. then you can config wiegand by ESPHome or write your own arduino code.
thanks man.
