KC868-A32 configure for ESPhome - Printable Version
+--- Forum: KC868-A32/A32 Pro (https://www.kincony.com/forum/forumdisplay.php?fid=27)
+--- Thread: KC868-A32 configure for ESPhome (/showthread.php?tid=1772)
Pages: 1 2
KC868-A32 configure for ESPhome - admin - 03-23-2022
  platform: ESP32
  board: esp32dev
# Example configuration entry
  - id: bus_a
    sda: 15
    scl: 13
  - id: bus_b
    sda: 4
    scl: 5
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
pcf8574:
    i2c_id: bus_a
    address: 0x24
    i2c_id: bus_a
    address: 0x25
  - id: 'pcf8574_hub_out_3'  # for output channel 17-24
    i2c_id: bus_a
    address: 0x21
  - id: 'pcf8574_hub_out_4'  # for output channel 25-32
    i2c_id: bus_a
    address: 0x22
    i2c_id: bus_b
    address: 0x24
    i2c_id: bus_b
    address: 0x25
  - id: 'pcf8574_hub_in_3'  # for input channel 17-24
    i2c_id: bus_b
    address: 0x21
  - id: 'pcf8574_hub_in_4'  # for input channel 25-32
    i2c_id: bus_b
    address: 0x22
# Individual outputs
      pcf8574: pcf8574_hub_out_1
      mode: OUTPUT
      number: 1
      mode: OUTPUT
      number: 2
      mode: OUTPUT
      number: 3
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
      number: 6
      mode: OUTPUT
      number: 7
      mode: OUTPUT
      pcf8574: pcf8574_hub_out_2
      mode: OUTPUT
      number: 1
      mode: OUTPUT
      number: 2
      mode: OUTPUT
      number: 3
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
      number: 6
      mode: OUTPUT
      number: 7
      mode: OUTPUT
      pcf8574: pcf8574_hub_out_3
      mode: OUTPUT
      number: 1
      mode: OUTPUT
      number: 2
      mode: OUTPUT
      number: 3
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
      number: 6
      mode: OUTPUT
      number: 7
      mode: OUTPUT
      pcf8574: pcf8574_hub_out_4
      mode: OUTPUT
      number: 1
      mode: OUTPUT
      number: 2
      mode: OUTPUT
      number: 3
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
      number: 6
      mode: OUTPUT
      number: 7
      mode: OUTPUT
      pcf8574: pcf8574_hub_in_1
      mode: INPUT
      number: 1
      mode: INPUT
      number: 2
      mode: INPUT
      number: 3
      mode: INPUT
      number: 4
      mode: INPUT
      number: 5
      mode: INPUT
      number: 6
      mode: INPUT
      number: 7
      mode: INPUT
      pcf8574: pcf8574_hub_in_2
      mode: INPUT
      number: 1
      mode: INPUT
      number: 2
      mode: INPUT
      number: 3
      mode: INPUT
      number: 4
      mode: INPUT
      number: 5
      mode: INPUT
      number: 6
      mode: INPUT
      number: 7
      mode: INPUT
      pcf8574: pcf8574_hub_in_3
      mode: INPUT
      number: 1
      mode: INPUT
      number: 2
      mode: INPUT
      number: 3
      mode: INPUT
      number: 4
      mode: INPUT
      number: 5
      mode: INPUT
      number: 6
      mode: INPUT
      number: 7
      mode: INPUT
      pcf8574: pcf8574_hub_in_4
      mode: INPUT
      number: 1
      mode: INPUT
      number: 2
      mode: INPUT
      number: 3
      mode: INPUT
      number: 4
      mode: INPUT
      number: 5
      mode: INPUT
      number: 6
      mode: INPUT
      number: 7
      mode: INPUT
  - platform: adc
    pin: 39
    update_interval: 10s
    attenuation: 11db
  - platform: adc
    pin: 34
    attenuation: 11db
  - platform: adc
    pin: 36
    attenuation: 11db
  - platform: adc
    pin: 35
    attenuation: 11db
RE: KC868-A32 configure for ESPhome - nwells - 03-03-2023
I'm having trouble connecting up remote transmitters as they won't accept the pcf8574 settings:
remote_transmitter:
  - id: master
      number: 5
      mode: INPUT
    carrier_duty_percent: 50%
climate:
  - platform: fujitsu_general
    transmitter_id: master
    name: "Master Bedroom - Air Conditioner"
    visual:
      min_temperature: 18
Also, I have multiple binary gpio setup but none of them are triggering. I can confirm they all work as I've setup them up previously on a smaller ESP32 supported board and I'm in the process of upgrading to the large A32 relay board.
    name: "PIR - Front Door"
    device_class: motion
    filters:
      - delayed_off: 30s
      number: 7
      mode: INPUT
RE: KC868-A32 configure for ESPhome - admin - 03-03-2023
check your A32 board PCF8574 IIC address value whether correct. after download firmware by ESPHome, see the LOG output, it will show the IIC scan address result.
(03-03-2023, 02:36 AM)admin Wrote: check your A32 board PCF8574 IIC address value whether correct. after download firmware by ESPHome, see the LOG output, it will show the IIC scan address result.
What about the remote transmitters? This is the compile error I get:
rc/main.cpp: In function 'void setup()':
src/main.cpp:377:85: error: no matching function for call to 'esphome::remote_transmitter::RemoteTransmitterComponent::RemoteTransmitterComponent(esphome::pcf8574::PCF8574GPIOPin*&)'
   master = new remote_transmitter::RemoteTransmitterComponent(pcf8574_pcf8574gpiopin);
The compile message appears as soon as I add pcf8574: pcf8574_hub_in_3
I've updated the firmware but still no progress.
I used the settings above:
  - id: bus_a
    sda: 15
    scl: 13
  - id: bus_b
    sda: 4
    scl: 5
pcf8574:
    i2c_id: bus_a
    address: 0x24
    i2c_id: bus_a
    address: 0x25
    i2c_id: bus_a
    address: 0x21
    i2c_id: bus_a
    address: 0x22
    i2c_id: bus_b
    address: 0x24
    i2c_id: bus_b
    address: 0x25
    i2c_id: bus_b
    address: 0x21
    i2c_id: bus_b
    address: 0x22
The logs report:
[19:09:08][C][i2c.arduino:052]: I2C Bus:
[19:09:08][C][i2c.arduino:053]:   SDA Pin: GPIO15
[19:09:08][C][i2c.arduino:054]:   SCL Pin: GPIO13
[19:09:08][C][i2c.arduino:055]:   Frequency: 50000 Hz
[19:09:08][C][i2c.arduino:058]:   Recovery: bus successfully recovered
[19:09:08][I][i2c.arduino:068]: Results from i2c bus scan:
[19:09:08][I][i2c.arduino:074]: Found i2c device at address 0x21
[19:09:08][I][i2c.arduino:074]: Found i2c device at address 0x22
[19:09:08][I][i2c.arduino:074]: Found i2c device at address 0x24
[19:09:08][I][i2c.arduino:074]: Found i2c device at address 0x25
[19:09:08][C][i2c.arduino:053]:   SDA Pin: GPIO4
[19:09:08][C][i2c.arduino:054]:   SCL Pin: GPIO5
[19:09:08][C][pcf8574:021]: PCF8574:
[19:09:08][C][pcf8574:022]:   Address: 0x24
[19:09:08][C][pcf8574:023]:   Is PCF8575: NO
[19:09:08][C][pcf8574:022]:   Address: 0x25
[19:09:08][C][pcf8574:022]:   Address: 0x21
[19:09:08][C][pcf8574:022]:   Address: 0x22
[19:09:09][C][pcf8574:021]: PCF8574:
[19:09:09][C][pcf8574:022]:   Address: 0x21
[19:09:09][C][pcf8574:023]:   Is PCF8575: NO
[19:09:09][C][pcf8574:022]:   Address: 0x22
Any ideas?
KC868-A32 no interface for RF receiver module, how do you use remote transmitters ?
(03-03-2023, 09:02 AM)admin Wrote: KC868-A32 no interface for RF receiver module, how do you use remote transmitters ?
I don't need a receiver. The transmitter is defined in my first post above. It worked fine when I had this on a different board - it just needs to send an output signal which is generated by the climate platform.
Could the GPIO issue be pullup related?
you are using PCF8574 IIC for GPIO work as transmitter. maybe PCF8574 speed not fast enough. you can try to set the PCF8574 frequency high, if also can't work , i think transmitter need use ESP32's GPIO, not PCF8574's.
How do I set the frequency to high?
about I2C bus setting in ESPHome, there ia a "frequency" setting.
details see here: https://esphome.io/components/i2c.html
