BUTTON SWITCH MODULE - How to add 2 remote controller to 1st channel? - Printable Version
+--- Thread: BUTTON SWITCH MODULE - How to add 2 remote controller to 1st channel? (/showthread.php?tid=191)
BUTTON SWITCH MODULE - How to add 2 remote controller to 1st channel? - Kam5 - 01-19-2021
Dear Admin I would like to connect 2remote controller from button switch board to operate only channel from 1-16 outputs. i don't need to use other outputs.
On the video You show how to add 2 remote controller to use all outputs. Please help with this solution.
Huh
RE: BUTTON SWITCH MODULE - How to add 2 remote controller to 1st channel? - admin - 01-20-2021
every remoter have different address, just let your yellow receiver module to learn which remoter is ok. here is a video details how to do:
https://youtu.be/4_YDX3bGI64
if you want two remoter all learn by first (left ) yellow receiver module, you can just learn again from second remoter is ok . (note: not to do clear code step! )
