KC868-A6 ESP32 I/O pin define - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A6 (https://www.kincony.com/forum/forumdisplay.php?fid=22) +--- Thread: KC868-A6 ESP32 I/O pin define (/showthread.php?tid=1962) |
KC868-A6 ESP32 I/O pin define - admin - 06-01-2022 #define ANALOG_A1 36 #define ANALOG_A2 39 #define ANALOG_A3 34 #define ANALOG_A4 35 DS18B20/DHT11/DHT21/LED strip -1: 32 DS18B20/DHT11/DHT21/LED strip -2: 33 DAC1:26 DAC2:25 IIC SDA:4 IIC SCL:15 Input_IIC_address 0x22 Relay_IIC_address 0x24 RS485 RXD: 14 RS485 TXD: 27 SPI_Bus: (For LoRA/nRF24L01) CS: 5 MOSI: 23 MISO: 19 SCK: 18 LoRA sx1278: RST:21 DIO0:2 nRF24L01: CE: 22 RS485: TXD:27 RXD:14 RS232: TXD:17 RXD:16 Extend serial port on PCB: TXD(define by yourself):12 RXD (define by yourself) :13 RE: KC868-A6 ESP32 I/O pin define - gilad - 05-03-2023 (06-01-2022, 07:23 AM)admin Wrote: #define ANALOG_A1 36 RE: KC868-A6 ESP32 I/O pin define - RenePL - 10-21-2023 I would like to use IO-1/IO-2 (originally intended for sensors ect. DS1820) as pure GIPO. ![]() I understand that I have to remove two resistors from the print. I need to use the board to communicate with the furnace via OpenTherm. What pins should I use for input/output? Design https://ihormelnyk.com/opentherm_adapter RE: KC868-A6 ESP32 I/O pin define - admin - 10-22-2023 IO1 and IO2 in KC868-A6 can use for DS18B20 directly. |
