Read Serial (RS485) Data - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KC868-Server Raspberry Pi4 local server (https://www.kincony.com/forum/forumdisplay.php?fid=17) +--- Thread: Read Serial (RS485) Data (/showthread.php?tid=1977) |
Read Serial (RS485) Data - v1rtus - 06-09-2022 Hello, I have no success to read data from RS485 port (orange one). I use NODE-RED for building flows. To make sure that it is not issue in any configuration I used USB->RS485 adapter and I had success to read data. There are two serial available when execute Code: dmesg | grep tty
I assume that /dev/ttyAMA0 is the right one to use but when I try to read data the response is "Modbus Failure On State sending Get More About It By Logging" Could someone help me with that? I can read data if I use USB->RS485 adapter but not trought the built-in RS-485 port (orange one). RE: Read Serial (RS485) Data - admin - 06-10-2022 if you use KC868-Server for RS485 modbus by Node-Red: 1. Enable serial port on Raspberry Pi CM4 The enable it you need to check in /boot/config.txt the line enable_uart enable_uart=1 2. use "/dev/ttyS0", not "/dev/ttyAMA0" today we will upload YouTube video about Node-Red control output by RS485 demo. RE: Read Serial (RS485) Data - admin - 06-10-2022 RE: Read Serial (RS485) Data - v1rtus - 06-10-2022 I have checked the config file and the serial port is enabled there. I switched from /dev/ttyAMA0 to /dev/tty/ttyS0 but with no success. It shows that port is connected but when I try to read data then I get error -> "Modbus Failure On State sending Get More About It By Logging" Could u help me with that? RE: Read Serial (RS485) Data - admin - 06-10-2022 do you have installed home assistant, or KC868-Server only installed Node-Red? RE: Read Serial (RS485) Data - v1rtus - 06-10-2022 I have only NODE-RED running in docker container. The operation system is latest Ubuntu Core. RE: Read Serial (RS485) Data - admin - 06-10-2022 do you using KC868-Server ? RE: Read Serial (RS485) Data - v1rtus - 06-10-2022 (06-10-2022, 10:55 AM)admin Wrote: do you using KC868-Server ? Yes I am using KC868-Server with CM4 on it. CM4 has Ubuntu Core running and NODE-RED is running in docker container. Everything works fine with USB-RS485 adapter but not with integrated port (orange one) RE: Read Serial (RS485) Data - admin - 06-10-2022 you can use serial port node for a test, firstly not use modbus, test whether "serial" node work well when use "/dev/tty/ttyS0". when you use "serial " , press scan button, will auto scan your hardware's serial , see whether can list the serial device. RE: Read Serial (RS485) Data - v1rtus - 06-10-2022 (06-10-2022, 11:16 AM)admin Wrote: you can use serial port node for a test, firstly not use modbus, test whether "serial" node work well when use "/dev/tty/ttyS0". when you use "serial " , press scan button, will auto scan your hardware's serial , see whether can list the serial device. do I need to install some package? I dont have serialport node available. |
