[Arduino IDE demo source code for KC868-A8S]--#14-KC868-A8S_mqtt-relay_code - Printable Version
+--- Forum: KC868-A8S (https://www.kincony.com/forum/forumdisplay.php?fid=24)
+--- Thread: [Arduino IDE demo source code for KC868-A8S]--#14-KC868-A8S_mqtt-relay_code (/showthread.php?tid=2009)
[Arduino IDE demo source code for KC868-A8S]--#14-KC868-A8S_mqtt-relay_code - KinCony Support - 06-30-2022
// make sure set your Serial2 pins in your "HardwareSerial.cpp" for ESP32 as follows:
//#define RX2  15
//#define TX2  13
// code use for KinCony KC868-A8S board
#include "PCF8574.h"
String Publish = "relay8/12345/state"; //Publish Topic
String Subscribe = "relay8/12345/set"; //Subscribe Topic
PCF8574 pcf8574_o(0x24,4,5);
PCF8574 pcf8574_i(0x22,4,5);
void setup()
  pinMode(2, OUTPUT);   //beep
  Serial2.begin(115200);
  pcf8574_i.pinMode(P0, INPUT);
  pcf8574_o.pinMode(P0, OUTPUT);
  pcf8574_o.pinMode(P1, OUTPUT);
  pcf8574_o.pinMode(P2, OUTPUT);
  pcf8574_o.pinMode(P3, OUTPUT);
  pcf8574_o.pinMode(P4, OUTPUT);
  pcf8574_o.pinMode(P5, OUTPUT);
  pcf8574_o.pinMode(P6, OUTPUT);
  pcf8574_o.pinMode(P7, OUTPUT);
    Serial.print("Init pcf8574_i...");
    if (pcf8574_i.begin()){
        Serial.println("PCF8674_input_OK");
    }else{
        Serial.println("PCF8674_input_KO");
    Serial.print("Init pcf8574_o...");
    if (pcf8574_o.begin()){
        Serial.println("PCF8674_output_OK");
    }else{
        Serial.println("PCF8674_output_KO");
  pcf8574_o.digitalWrite(P0, HIGH);
  pcf8574_o.digitalWrite(P1, HIGH);
  pcf8574_o.digitalWrite(P2, HIGH);
  pcf8574_o.digitalWrite(P3, HIGH);
  pcf8574_o.digitalWrite(P4, HIGH);
  pcf8574_o.digitalWrite(P5, HIGH);
  pcf8574_o.digitalWrite(P6, HIGH);
  pcf8574_o.digitalWrite(P7, HIGH);
  //AT Commands for setting up the client id and Server
  //Need to be executed once -- Open serial terminal doe seeing the debug messages
  Serial.println("Connecting To Server........");
  Serial2.println("ATE1");
  delay(2000);
  Serial2.println("AT+CMQTTSTART"); //Establishing MQTT Connection
  delay(2000);
  Serial2.println("AT+CMQTTACCQ=0,\"kincony\""); //Client ID - change this for each client as this need to be unique
  delay(2000);
  Serial2.println("AT+CMQTTCONNECT=0,\"tcp://iot.kincony.com:1883\",120,1,\"mqtt\",\"123\""); //MQTT Server Name for connecting this client  user name: mqtt   password: 123
  delay(2000);
  Serial2.println("AT+CMQTTSUB=0,16,1,1"); //Length of message
  delay(1000);
  Serial2.println("relay8/12345/set"); //message
  delay(1000);
  Serial.println("Done");
void loop()
  String incoming;
//Receiving MODEM Response
  while(Serial2.available()>0)
    delay(10);
    incoming = Serial2.readString();
    Serial.println(incoming);
    //Serial.println(b);
    if(incoming.indexOf("PAYLOAD") != -1)
       int new1 = incoming.indexOf("PAYLOAD");
       String neww = incoming.substring(new1);
       int new2 = neww.indexOf('\n');
       String new3 = neww.substring(new2+1);
       int new4 = new3.indexOf('\n');
       String new5 = new3.substring(0,new4);
       Serial.println("Topic: relay/subscribe");
       Serial.print("Message is: ");
       Serial.println(new5);
       new5.remove(new5.length()-1);
       if(new5 == "{\"relay1\":{\"on\":1}}")
        Serial.println("relay1 ON");
        pcf8574_o.digitalWrite(P0, LOW);
      Serial.println("Publishing Message: relay1 ON");
      Serial2.println("AT+CMQTTTOPIC=0,18"); //AT Command for Setting up the Publish Topic Name
      delay(1000);
      Serial2.println(Publish); //Topic Name
      delay(1000);
      Serial2.println("AT+CMQTTPAYLOAD=0,19"); //Payload length
      delay(1000);
      Serial2.println("{\"relay1\":{\"on\":1}}"); //Payload message
      delay(1000);
      Serial2.println("AT+CMQTTPUB=0,1,60"); //Acknowledgment
      delay(1000);
       else if(new5 == "{\"relay1\":{\"on\":0}}")
        Serial.println("relay1 OFF");
      Serial.println("Publishing Message: relay1 OFF");
      delay(1000);
      delay(1000);
      delay(1000);
      Serial2.println("{\"relay1\":{\"on\":0}}"); //Payload message
      delay(1000);
      delay(1000);
