Uair - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: DIY Project (https://www.kincony.com/forum/forumdisplay.php?fid=3) +--- Thread: Uair (/showthread.php?tid=2013) |
Uair - ahmedwizza - 07-04-2022 can we make scnce from alexa by Uair after integration with homeassistant?????????????? RE: Uair - admin - 07-04-2022 sure, if you integrate to home assistant, create "automation" in home assistant. RE: Uair - ahmedwizza - 07-04-2022 (07-04-2022, 10:10 PM)admin Wrote: sure, if you integrate to home assistant, create "automation" in home assistant. can it work with kbox local without internet?????? RE: Uair - admin - 07-05-2022 kbox user for relay controller and dimmer, not for KC868-Uair, if you want to use by local network without internet: 1. use by home assistant, it work locally. 2. enable esphome http web service, so that you can use wifi ip address login by web browser in local network. |
