New DIY Project Support - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: DIY Project (https://www.kincony.com/forum/forumdisplay.php?fid=3) +--- Thread: New DIY Project Support (/showthread.php?tid=2025) |
New DIY Project Support - ahmedk4444@yahoo.com - 07-07-2022 Dear kincony support, I bought those from Kincony 1 server 1 A16 bundle E 2 D8 + 16 SSR 10A + 16 CB 6A 1 H32BS+ 2 E8 + 16 CB 10 A 1 power supply 220/12 volt 4.5A I need to know the exact wiring diagram need it between Server ,A16 Bundle E , 2D8, H32BS to start build the distribution board. Note the lesson 3 demo just showing server with A16 and connect the server directly to load through E16 only Thanks RE: New DIY Project Support - KinCony Support - 07-08-2022 Picture 01 KC868-SERER and KC868-A16 and KC868-E16(KC868-E8 is the same) Picture 02 KC868-SERER and KC868-BS and KC868-E16(KC868-E8 is the same) and KC868-D8 RE: New DIY Project Support - ahmedk4444@yahoo.com - 07-10-2022 (07-08-2022, 12:53 AM)KinCony Support Wrote: Picture 01 KC868-SERER and KC868-A16 and KC868-E16(KC868-E8 is the same) RE: New DIY Project Support - KinCony Support - 07-11-2022 (07-10-2022, 03:21 AM)ahmedk4444@yahoo.com Wrote:(07-08-2022, 12:53 AM)KinCony Support Wrote: Picture 01 KC868-SERER and KC868-A16 and KC868-E16(KC868-E8 is the same) RE: New DIY Project Support - ahmedk4444@yahoo.com - 07-11-2022 Thanks for short reply As i understood there is no neccessary to connect A16 and server to load through E8 or E16 relays since the H32BS and D8 connected and sufficient for that purpose. This mean A16 and the server to provide Support to all controllers on the computer network controllers ( AG, D8 H32B, H32BS, ...etc) using home asistance only. Since my lighting on/off load is 16 circuits only if i knew this earlier of order wouldn't order H32BS and use the server to do it that connect to the load through 2E8 or E16 and save the cost of H32BS. Last but not list what is advantage to add A16 to the server and what is the adding value for this? In my casr as i understood from reply power on the server, A16 and connect to ethermet / wifi and install configure software to support the all KC controllers and no load connected to the server/A16 in tjis case. RE: New DIY Project Support - KinCony Support - 07-12-2022 (07-11-2022, 03:07 PM)ahmedk4444@yahoo.com Wrote: Thanks for short reply Hello, There are several ways to control load: 1.KC868-A16+E16(1PCS)+Breaker and load----can control 16 Channels 2.KC868-H32BS+E16(2PCS)+Breaker and load----can control 32 Channels 3.KC868-Server+E16(2PCS)+Breaker and load----can control 32 Channels support home assistant 4.KC868-Server+KC868-A16+E16(3PCS)+Breaker and load----can control 48 Channels support home assistant RE: New DIY Project Support - ahmedk4444@yahoo.com - 07-12-2022 Based on your reply and since i bought KC-868 server KC-868 -A16 Can control up to 48 circuit using 3 E16 and i had 2 E8 And my lighting on/ off load is 16 circuit with possible extensionvthen no need to H32BS and may be better increase 4 E8 to use up to 48 circuit. Can i replace ( return ) the H32BS with order new 4 E8? Saving space in distribution board. Also i understood server with A16 better for home asistance with D8 and 4 AG Do you agree that no need for H32BS? I recommend that you use KC868-server as the server, H32BS+E16 or E8 for load control, in this way you can connect to switch panel, if you only use KC868-server, you can only connect to 16 switch panel, with H32BS, you can extend to 48 switch panel. A16 cannot be connected to switch panel. RE: New DIY Project Support - admin - 07-14-2022 KC868-Server+ KC868-A16 = 32 channel output, not 48 channel. A series board need config by ESPHome, need familiar with esphome configuration. H series board , such as H32BS, it's the most powerful, almost directly to use, many function will be simple set in his webpage. such as "double click" function and momentary time setting.... actually, KC868-H32BS + KC868-E16 is the best combination. RE: New DIY Project Support - ahmedk4444@yahoo.com - 07-15-2022 Thank you Then keep the same plan setup RE: New DIY Project Support - admin - 07-15-2022 you are welcome. |
