KC868-S/G in Home;Assistant and Nore-Red - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KC868-HxB series Smart Controller (https://www.kincony.com/forum/forumdisplay.php?fid=2) +--- Thread: KC868-S/G in Home;Assistant and Nore-Red (/showthread.php?tid=203) |
KC868-S/G in Home;Assistant and Nore-Red - Edimar3103 - 01-27-2021 Is it prossible program KC-868-S/G in node-red to use it in home assistant? There is a communication protocol? RE: KC868-S/G in Home;Assistant and Nore-Red - admin - 01-27-2021 no problem , we have already make the video. KC868-G protocol is here: https://www.kincony.com/download/KC868-G-Protocol.pdf KC868-S' protocol as same as KC868-G's, just KC868-S is ethernet version. this is video for KC868-G connect to your own server's demo: https://youtu.be/Q7D3bjzkhr4 this is video for KC868-G use in local network without internet: https://youtu.be/oENXInWr3k8 RE: KC868-S/G in Home;Assistant and Nore-Red - Macgyver - 10-18-2021 What Rf 433 switch can you use to control the blind so that I can control via Kc868-G RE: KC868-S/G in Home;Assistant and Nore-Red - admin - 10-18-2021 you can use any 433M wireless switch panel that can learn EV1527 code is ok. |
