Sensor PIR + KC868-W32+Home Assistant - Printable Version
+--- Thread: Sensor PIR + KC868-W32+Home Assistant (/showthread.php?tid=204)
Sensor PIR + KC868-W32+Home Assistant - Edimar3103 - 01-27-2021
How can I program in Node-Red to turn on a light when a PIR sensor detect somebody? How can I perform what period of the day this action will should be performed.
RE: Sensor PIR + KC868-W32+Home Assistant - admin - 01-27-2021
if you use Node-Red, read controller's input state (PIR have connect with input port), if trigger, then read now time value, if it's within the time allowed, do relay output.
RE: Sensor PIR + KC868-W32+Home Assistant - athxp - 06-25-2021
I would need to do such a thing.
can i use node red to program on col?
RE: Sensor PIR + KC868-W32+Home Assistant - admin - 06-26-2021
replied in another thread, you just use relay controller phone app to set timer is ok.
