led doesn't light up - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A16 (https://www.kincony.com/forum/forumdisplay.php?fid=25) +--- Thread: led doesn't light up (/showthread.php?tid=2115) |
led doesn't light up - 2sdaymars - 08-05-2022 I bought it and used it, but it doesn't work. I put the code on esphome and turned on the switch, but the led doesn't light up. i use this code esphome: name: a16 platform: ESP32 board: esp32dev # Example configuration entry for ESP32 i2c: sda: 4 scl: 5 scan: true id: bus_a # Example configuration entry pcf8574: - id: 'pcf8574_hub_out_1' # for output channel 1-8 address: 0x24 - id: 'pcf8574_hub_out_2' # for output channel 9-16 address: 0x25 - id: 'pcf8574_hub_in_1' # for input channel 1-8 address: 0x21 - id: 'pcf8574_hub_in_2' # for input channel 9-16 address: 0x22 # Individual outputs switch: - platform: gpio name: "light1" pin: pcf8574: pcf8574_hub_out_1 # Use pin number 0 number: 0 # One of INPUT or OUTPUT mode: OUTPUT inverted: false - platform: gpio name: "light9" pin: pcf8574: pcf8574_hub_out_2 # Use pin number 0 number: 0 # One of INPUT or OUTPUT mode: OUTPUT inverted: false binary_sensor: - platform: gpio name: "input1" pin: pcf8574: pcf8574_hub_in_1 # Use pin number 0 number: 0 # One of INPUT or OUTPUT mode: INPUT inverted: false - platform: gpio name: "input9" pin: pcf8574: pcf8574_hub_in_2 # Use pin number 0 number: 0 # One of INPUT or OUTPUT mode: INPUT inverted: false # Enable logging logger: # Enable Home Assistant API api: encryption: key: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxx" ota: password: "xxxxxxxxxxxxxxxxx" wifi: ssid: !secret wifi_ssid password: !secret wifi_password # Enable fallback hotspot (captive portal) in case wifi connection fails ap: ssid: "xxxxxxxxxxxxxxx" password: "xxxxxxxx" captive_portal: RE: led doesn't light up - admin - 08-05-2022 do you have connect power with MOSFET output's terminal? need connect with DC12V, every 8 channel MOSFET output use a common DC power supply input. see "12/24V DC input" in photo.
RE: led doesn't light up - 2sdaymars - 08-05-2022 thanks so much its work is there no 16-channel Arduino coding? RE: led doesn't light up - admin - 08-05-2022 there are many arduino IDE demo source code, you can download at here: https://www.kincony.com/forum/forumdisplay.php?fid=25 [Arduino IDE demo source code for KC868-A16] series topic. RE: led doesn't light up - 2sdaymars - 08-05-2022 I am looking for a code to control 16 channel MOSFETs with Arduino mqtt communication~ i couldn't find RE: led doesn't light up - admin - 08-05-2022 you can modfiy with this demo source code: https://www.kincony.com/forum/showthread.php?tid=1843 this is KC868-A4 wifi work with MQTT, you just need add I2C code for mosfet output with A16. RE: led doesn't light up - 2sdaymars - 08-05-2022 THANKS YOU SO MUCH RE: led doesn't light up - admin - 08-05-2022 you are welcome |
