KC 868 AG - YAML Code - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: Development (https://www.kincony.com/forum/forumdisplay.php?fid=4) +--- Thread: KC 868 AG - YAML Code (/showthread.php?tid=2162) |
KC 868 AG - YAML Code - nrnr - 08-23-2022 I've edited YAML code for IR gateway. I'm recieving error message related to "if" command - "Component not found if." The code: remote_receiver: pin: GPIO23 dump: all binary_sensor: - platform: remote_receiver name: "TEST" pronto: data: "0000 006D 0022 0000 0151 00AD 0015 0014 0017 0041 0015 0014 0017 0016 0015 0044 0012 0014 0017 0044 0013 0018 0013 0043 0013 0016 0015 0044 0012 0044 0013 0016 0015 0043 0013 0016 0015 0044 0013 0016 0015 0041 0016 0015 0015 0041 0016 0040 0015 0014 0017 0013 0018 0013 0018 003F 0018 0013 0018 003F 0019 0012 0018 0013 0018 003F 0018 003F 0018 003F 0018 06C3" if: condition: binary_sensor.is_on: TEST then: - mqtt.publish: topic: IR_Bridge payload: "Something happened!" component not found if. component not found if. RE: KC 868 AG - YAML Code - admin - 08-23-2022 # In some trigger: on_...: if: condition: # Same syntax for is_off binary_sensor.is_on: my_binary_sensor RE: KC 868 AG - YAML Code - admin - 08-23-2022 you can use 433M receiver make a binary sensor for a test firstly. RE: KC 868 AG - YAML Code - nrnr - 08-24-2022 (08-23-2022, 10:54 PM)admin Wrote: # In some trigger: Thanks What is the meaning of "on_...:" ? RE: KC 868 AG - YAML Code - admin - 08-24-2022 here is details on esphome official webpage: https://esphome.io/components/binary_sensor/index.html |
