Alexa connected to Node-RED unable to turn On and OFF Raspberry Pi 3 GPIO LED - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: DIY Project (https://www.kincony.com/forum/forumdisplay.php?fid=3) +--- Thread: Alexa connected to Node-RED unable to turn On and OFF Raspberry Pi 3 GPIO LED (/showthread.php?tid=217) |
Alexa connected to Node-RED unable to turn On and OFF Raspberry Pi 3 GPIO LED - pdhanaraj10 - 02-21-2021 After watching sir's video i have bridged my Alexa and Node-RED, but whenever i turn on the switch in Alexa, Alexa says "Switch is turn On" but there is no response at the output sir. I got these errors in my Raspberry Pi terminal: Error: getDevices status: 401 Error: getDevices returned data: undefined I have no problem in the flow as i can connect and interact with my Alexa trough Noed-RED but i have selected GPIO [pin 5] as my output pin in which i cant get observe any response. Debug also indicates that switch is On and Off respectively. i fear there is miss connection of server. im from Malaysia. RE: Alexa connected to Node-RED unable to turn On and OFF Raspberry Pi 3 GPIO LED - admin - 02-21-2021 do you have upload the image? can't see anything. RE: Alexa connected to Node-RED unable to turn On and OFF Raspberry Pi 3 GPIO LED - admin - 02-21-2021 check Sinric account whether work fine. RE: Alexa connected to Node-RED unable to turn On and OFF Raspberry Pi 3 GPIO LED - pdhanaraj10 - 02-21-2021 (02-21-2021, 02:42 AM)admin Wrote: check Sinric account whether work fine. i didnt use github. i did a account in Node-RED and i link it trough Alexa. then in alexa i enabled node-red skill. RE: Alexa connected to Node-RED unable to turn On and OFF Raspberry Pi 3 GPIO LED - admin - 02-21-2021 my means is Sinric skill whether register, not the Node-Red. |
