KC868-A8S_WS2812-RGB_LED - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: Development (https://www.kincony.com/forum/forumdisplay.php?fid=4) +--- Thread: KC868-A8S_WS2812-RGB_LED (/showthread.php?tid=2187) |
KC868-A8S_WS2812-RGB_LED - garrip - 08-24-2022 I am trying to use this example code [Arduino IDE demo source code for KC868-A8S]--#08-KC868-A8S_WS2812-RGB_LED_code but WS2812 is alway off. PIN 12 is LOW. I'm wrong, but I can not understand why. I test output, input (digital and analog), GSM, and RF433 using my code, everything works fine. I can't get it to work (tried different code and library) is the RBG WS2812 led on the board only. I tested my code on RBG WS2812 ring using a ESP32-Wrover-E and it works. Can someone help me, please? Can someone tell me how I can download a demo firmware, when I turn on the board the first time, the led changed color. I want to test the RBG WS2812 LED, so if I have broken it, I'll change with a new one. Thank, best regards. Marco RE: KC868-A8S_WS2812-RGB_LED - admin - 08-25-2022 can you take a video of your problem, upload to google driver, leave the video link at here, i can check. RE: KC868-A8S_WS2812-RGB_LED - csacomani - 09-26-2024 Hello! I'm testing the RGBW LED on the KC868-A8S board, using the code: Code: light: but when I choose a color, it doesn't turn on the chosen color, for example, if I choose the color red, the LED turns green. Do I have to do some kind of calibration or use another code? RE: KC868-A8S_WS2812-RGB_LED - admin - 09-26-2024 take a photo how you wire. RE: KC868-A8S_WS2812-RGB_LED - csacomani - 09-27-2024 I'm using the LED from the KC868-A8S board itself: "RGB LED WS2812. If not have display, then at least a multi-color LED, which can also notify about various events and states of the system." KC868-A8S |
