Fireplace stove combustion automation - Printable Version
+--- Thread: Fireplace stove combustion automation (/showthread.php?tid=2243)
Fireplace stove combustion automation - SvetZitrka - 09-06-2022
Hi, I would like to equip my fireplace insert with an automation that will measure the temperature of the flue gas in the chimney and control the air supply damper based on that.
Systems like this can make the whole burning process much more efficient, using up to 30% less wood. Which is great. Plus, they can be very user-friendly and alert the user to add wood to the fireplace.
All you have to do is measure the temperature with a ceramic sensor that can withstand high temperatures and a servo drive to control the air supply damper.
All the logic should be able to be set up through Home Assistant.
  • Which HW Kincony would handle this and how?
  • Can you give me any advice?
I believe that similar automation would save many users a lot of stress, especially now that winter is coming and there is an energy crisis.
RE: Fireplace stove combustion automation - admin - 09-06-2022
I think you need to choose the right industrial grade sensor and servo motor driver first, and then we will recommend the corresponding hardware controller for you. Because there are many kincony's products can be used, but need to know your sensor test range firstly.
RE: Fireplace stove combustion automation - Kross Piter - 09-16-2022
(09-06-2022, 10:40 AM)SvetZitrka Wrote: Hi, I would like to equip my fireplace insert with an automation that will measure the temperature of the flue gas in the chimney and control the air supply damper based on that.
Hey! Have you found the solution?
RE: Fireplace stove combustion automation - admin - 09-16-2022
you need to choose the right industrial grade sensor and servo motor driver firstly. suggest chose analog output DC 0-5v sensor, then you can use KC868-COLB and smart relay controller connect to home asisstant. relay controller you need to calculate the total relay number you will use.
