How to connect button switch module - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KC868-HxB series Smart Controller (https://www.kincony.com/forum/forumdisplay.php?fid=2) +--- Thread: How to connect button switch module (/showthread.php?tid=225) |
How to connect button switch module - Adrian - 03-02-2021 How to connect wired switch panel with touch sensor (e.g. https://www.aliexpress.com/item/32761180385.html) to button switch module for KC868-Hx relay (https://www.kincony.com/button-switch-module-for-kc868-hx-relay-controller.html). These types of switches are fashionable and look better than the standard ones ... Maybe there is one that was powered by DC12V and worked with Kincony button switch module? RE: How to connect button switch module - admin - 03-03-2021 now touch panel almost use by AC220V , it directly to control AC220V load ON/OFF. because it's use touch sensor, so the self-reset type switch panel is more stable. |
