Poor IR transmitter range - Printable Version
+--- Forum: KC868-AG / AG Pro / AG8 (https://www.kincony.com/forum/forumdisplay.php?fid=30)
+--- Thread: Poor IR transmitter range (/showthread.php?tid=2253)
Poor IR transmitter range - onlyoneme - 09-08-2022
Hello, I've just bought this device and after some preliminary tests I've noticed that IR range is terribly poor comparing to my another transmitter, which is a cheap Tuya based device.
Is it a matter of weak IR LEDs or reason is something else?
RE: Poor IR transmitter range - admin - 09-08-2022
KC868-AI is not based on tuya solution.
can you open the box to test the IR range.
Maybe you can adjust the angle of the internal infrared emitter.
RE: Poor IR transmitter range - onlyoneme - 09-10-2022
(09-08-2022, 11:32 AM)admin Wrote: KC868-AI is not based on tuya solution.
I've tried without the top case. It's a bit better but still below my expectations.
Tasmota's guides recommend usage of TSAL6400 leds. Are the ones used in KC868-AG on similar level in terms of effective IR range?
RE: Poor IR transmitter range - admin - 09-10-2022
KC868-AG use IR333C-A 5MM.
