Do the relays support inching switching? - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KC868-HxB series Smart Controller (https://www.kincony.com/forum/forumdisplay.php?fid=2) +--- Thread: Do the relays support inching switching? (/showthread.php?tid=24) |
Do the relays support inching switching? - admin - 10-30-2020 Do the relays support inching switching? I need the relay to turn on for 1 second and then automatically turn off. Answer: Controller's inching switching function support by software. You can create scene mode in our "KinCony smart home" phone app. Also we have "KBOX" local network version app, that can set button for "CLICK" or "TOUCH" mode, that works without internet. RE: Do the relays support inching switching? - James Alabama - 04-12-2021 (10-30-2020, 01:19 AM)admin Wrote: Do the relays support inching switching? I need the relay to turn on for 1 second and then automatically turn off. The "touch" mode in KBOX works very well for inching switching which is necessary for some devices. Is it possible to do this (like "touch" mode) from the PC CX app? or from the new pad/pc "KC868 smart home control system"? James RE: Do the relays support inching switching? - admin - 04-12-2021 PC CX app already support , that's auto off function, you can preset before you use. Do you use H32 relay controller? new PC softare https://www.kincony.com/download/MulitiBoardCtrlV1.0.3.0324.zip also have support "TOUCH" mode. RE: Do the relays support inching switching? - James Alabama - 04-13-2021 (04-12-2021, 08:15 AM)admin Wrote: PC CX app already support , that's auto off function, you can preset before you use. Do you use H32 relay controller? Hello again and sorry to keep troubling you: 1. I have H32L controller but I can't find where to "preset auto off function"? 2. I downloaded and unzipped "MultiBoardCtrl" software but don't know what to do with this. Can you link me to a video or instructions? James Please discard my second question. I added H32L and COLB to Multicontroller. James RE: Do the relays support inching switching? - James Alabama - 04-13-2021 With regard to question 1, I found the Auto OFF feature with the menu and parameter config tabs. However it seems to put ALL relays in this inching configuration. Is there a relay specific command for the Auto OFF (inching) feature? I just want to assign this property to some, but not All relays? James RE: Do the relays support inching switching? - admin - 04-13-2021 you can use new version PC software , download from: https://www.kincony.com/download/MulitiBoardCtrlV1.0.3.0324.zip it can running on windows PC or 10 inch tablet. you can set any relay work mode for "CLICK" or "TOUCH" RE: Do the relays support inching switching? - admin - 04-13-2021 before click "connect" button, use mouse right button click relay ico will see the setting window. RE: Do the relays support inching switching? - James Alabama - 04-13-2021 (04-13-2021, 03:44 AM)admin Wrote: you can use new version PC software , download from: https://www.kincony.com/download/MulitiBoardCtrlV1.0.3.0324.zip Excellent, this is very nice functionality. Thank you. |
