KC868-HA RS485 Button Adapter Released - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: News (https://www.kincony.com/forum/forumdisplay.php?fid=5) +--- Thread: KC868-HA RS485 Button Adapter Released (/showthread.php?tid=2403) |
KC868-HA RS485 Button Adapter Released - admin - 11-21-2022 We have designed KC868-HA RS485 button adapter, let your old switch or traditional switch become smart, work with KC868-H32B Pro smart relay controller, use any “Latch” or “Momentary” switch panel work with your smart home automation. This time, regular switch can be used in smart home system. ![]()
RE: KC868-HA RS485 Button Adapter Released - Sten - 11-23-2022 Hi Is it working with KC868-32BS or KC868-32B? Regards Sten RE: KC868-HA RS485 Button Adapter Released - admin - 11-23-2022 now it's working with KC868-H32B Pro, in furture we will update KC868-H32BS' firmware to support it. RE: KC868-HA RS485 Button Adapter Released - Sten - 11-23-2022 (11-23-2022, 10:53 AM)admin Wrote: now it's working with KC868-H32B Pro, in furture we will update KC868-H32BS' firmware to support it. Hi Thank you for quick response! But update for KC868-H32B? Do you have information when the new switch terminal board will be available? Regards Sten RE: KC868-HA RS485 Button Adapter Released - admin - 11-23-2022 Because H32B not have RS485 interface. new switch terminal board will be available in next week, these days will take video tour about it. RE: KC868-HA RS485 Button Adapter Released - Sten - 11-26-2022 (11-23-2022, 11:36 AM)admin Wrote: Because H32B not have RS485 interface. Hi Does the KC868-AH switch board support 1-click, 2-click , hold on actions? Like the KC868-AK switch terminal board Regards Sten RE: KC868-HA RS485 Button Adapter Released - admin - 11-26-2022 KC868-HA only support 1-click, because mainly use for old latch switch, that not easy for double click. RE: KC868-HA RS485 Button Adapter Released - Sten - 11-26-2022 (11-26-2022, 11:11 AM)admin Wrote: KC868-HA only support 1-click, because mainly use for old latch switch, that not easy for doubleHi Does the KC868-HA support updates? if yes, then do you plan this double klick and hold function update? Regards Sten RE: KC868-HA RS485 Button Adapter Released - admin - 11-27-2022 sure, KC868-HA support use firmware download tool as relay controller. if many user want double click function, we will update firmware to support it, hardware not need to change any. RE: KC868-HA RS485 Button Adapter Released - Sten - 01-25-2023 (11-27-2022, 01:38 AM)admin Wrote: sure, KC868-HA support use firmware download tool as relay controller. if many user want double click function, we will update firmware to support it, hardware not need to change any. Hello Have you considered adding a double click and hold function to KC868-HA? |
